Question about Dryers
My fan stopped working. I need just the motor/fan blade assembly which I removed from the housing. Can I get that part only.
  • Fred May 11, 2010
    what sort of fan is it? there is a thermal fuse inside the fan housing and once those go out they no longer operate.......they can be replaced
  • bulldogchief
    bulldogchief May 11, 2010
    Depends, what is the make and model number of your fan?
    President:
  • 1,187 Answers
You can replace the motor only .... yes.
You may get some new bolts with that, too.
Any auto parts store has the fan motor.. ($20)
If you have trouble removing the fan blade from the motor, the store will remove it for you (free).
Hope this helps!
Posted on Sep 10, 2009
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Vornado fan Model CR1-0023 , Type 750 I bought this fan used 3 days ago. Seemed to work fine but not as powerfully as another new Vornado shop fan I have. Today the fan blades stopped turning. I can...
I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)
Jul 27, 2011 | Vornado CR10023-06 Air Circulator Fan
I have a Nutone 672rb bathroom exhaust fan. About 10 years old with no maint to date. Fan is laboring and sounds like binding up. I removed it and am trying to get the white circular "fan" off...
For most ceiling exhaust fans, the motor portion is usually attached to a metal housing plate. If this is the case, there is usually a hex or phillips screw on one side or perhaps in a corner which retains the entire housing plate. The motor assembly is usually attached to this plate. Unplug the motor wire inside the fan housing. Remove this retaining screw and look to see if one side can slip downward while the opposite side is usually retained by two metal tabs that are in metal side wall slots. If sliding down the retainer housing is working, then once clear of the metal frame you can pull backward away from the side wall to release the two tabs from their slots. By now you should have the motor assembly and fan blade assembly in your hands ready to dismantle, or clean & lubricate as needed.
Nimsgame
Feb 14, 2011 | Home
My 1988 Ford Tempo's heater fan is not working. I can feel heat at the windshield vents,but the fan wont come on. I have jumped the fan speed switch with a paper clip--and blew a fuse--and checked the...
your circuit is simple--I will paste it below. suspect the blower has shorted and caused the switch to burn up. remove the blower and hotwire it to the battery to see if it works. If not, replace the blower. Then run continuity tests on the swoitch and replace switch if bad. If you have questions, please let me know. Here is procedure for taking blower out:
REMOVAL & INSTALLATION With Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment by removing the retaining screws and bolts. Push the sides of the glove box in to free the drawer from dash panel.
  3. Loosen the instrument panel at the lower right hand of the glove compartment opening. This is on it necessary if the panel is in the way of the motor housing.
  4. Remove the retaining screws securing the ducting around the blower motor.
  5. Remove the clip securing the blower motor fan blade to the motor arm. Remove the fan blade from the motor.
  6. Remove the blower motor mounting plate from the evaporator case by unscrewing the retaining screws.
  7. Rotate the motor until the mounting plate clears the edge of the glove compartment opening and remove the motor.
  8. Remove the wire harness from the rear of the motor.
  9. Inspect the fan blade for broken edges or cracks. Replace if needed.
To install:
  1. Connect the wire harness to the rear of the blower motor.
  2. Install the motor into the case and secure with the retaining screws.
  3. Position and fasten the fan blade to the blower motor arm. Secure with the clip.
  4. Secure the blower motor outer housing to the duct assembly with the retaining screws.
  5. Install the instrument panel at the lower right hand side if removed earlier.
  6. Install the glove compartment door and glove compartment.
  7. Connect the negative battery cable.
  8. Run blower motors to make the motor works correctly.
Without Air Conditioning
  2. Remove the right ventilator assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cab
  6. Check the system for proper operation.
Oct 21, 2010 | 1988 Ford Tempo
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Motor problem
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 04, 2008 | Vornado Circulating Fan
Noisey fan
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Dec 08, 2007 | Broan-NuTone N-8664RP Combination Light...
Dryers Logo
136 people viewed this question
Top Dryers Experts
