I was given a Xenon flat screen monitor. The back has 4 usb ports and 1 usb input and an analog rgb port. It came with no cables. Can I just use a usb cable or do i need the analog rgb cable? Also when I turned it on.. the power light is blinking orange. Thank you! Kim
    President:
  • 1,187 Answers
The USB hub/connections cannot be used for driving the monitor... It is only an extra feature so that you can connect USB devices (such as a mouse & keyboard or flash drive) at the monitor instead of the computer ports.
You must use the RGB/VGA connection to use the monitor.
When you turn ON the monitor, it should "announce" itself with a logo...
When you were given the monitor, were you told that it works?
Please connect the monitor and comment back...
Thanks!
Posted on Sep 10, 2009
Testimonial: "Thank you! I dont have the vga/rgb connector. my friend said they didnt know if it worked or not. Should the logo come up even when its not pluged int"
  • Just Gort
    Just Gort Sep 10, 2009
    The logo should come on under all circumstances.... It presents a "Energy Star" "star" logo.
    Don't worry if it doesn't show up... the monitor screen may still be starting up and the logo has already cleared from the screen. It is more noticable when ever you reboot or the monitor is turned off and back on. If you still don't see it, it doesn't mean that the monitor is broken.
Screen shattered I want to hook up my mini Toshiba Laptop model number NB505-N508BL to my Toshiba tv. How do I do it and what do I need to do it? I think you messed up on the tv part i have a Toshiba tv...
1. Get an RGB cable.
2. Plug one end of the cable to the laptop VGA/RGB port.
3. Plug the other end of the cable to the RGB/PC input port of the TV.
4. Select the output of the laptop to the VGA/RGB port.
5. Press the Video button (usually with a sign of an arrow inside a circle) and choose PC.
Jul 02, 2014 | Computers & Internet
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Switching CRT to LED with 'input not supported" in Vista
It sounds like the computer is sending a signal to the monitor, but the monitor is not happy with the signal.
First, I'd check the cables. Make sure they're all plugged in solidly to the right ports. If you have a spare cable, swap it out to see if it helps. Note that Component Video is not the same as RGB, so you can't just plug an RGB cable into Component jacks.
Did the monitor come with software that needs to be installed? Make sure that's installed.
Check the monitor manual for what kinds of input it can accept. Check your computer's manual for what kind of video output it can produce. Make sure you're using a protocol that both can work with.
Try connecting the monitor to another computer. Maybe the monitor is faulty.
Try using a different video protocol. If you were using your computer's HDMI port, does it have an RGB port? Can you use USB?
Oct 22, 2017 | Computers & Internet
Where to connect my pen drive in my sony bravia lcd klv32s400a?
Hi Radhika,
Your TV has USB port on back side. Just plug your pendrive there. Then go menu on TV ( use your remote commander) and go to this input. Your TV will read the file on pendrive accordingly.
Regards
Oct 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Can't hook up my laptop to play DVD's through my Eiki LC-XNB4M
computer should always be connected with 15 pin VGA to DVI-I cable.
Select in menu input 1 analog RGB and adjust output resolution of Dell to 1024 x 768. this should work !
USB is only for mouse control with pj remote
Jul 09, 2010 | Eiki LC-SM4 Multimedia Projector
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
My sharp tv is pc ready. I hook everything up and nothing works. Tried hdmi and also tried RGB-vga cables. If I put cable in hdmi port nothing happens. If I use RGB cable and audio nothing happens. If I...
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Mar 12, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
