Question about Canon PIXMA MP150 All-In-One InkJet Printer
Printer Trouble My printer doesnt print it just sucks up a couple of centimeteres of a corner. it will say E1,2 or 3 and the alarm light will turn. i some how managed 2 get it 2 suck up a full piece of paper but it jammed inside it. Could you help. Thanks
  • 41 Answers
Re: Printer Trouble
Can you try to reset?...
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Posted on Feb 11, 2008
0 characters
3 Points
I spent lots of time last night trying to get my printer to work - it did a couple times and now it won't print out again - trying to print from the computer to the printer.
IF THE PRINTER has any ALARM LIGHT. check for paper jam or BAD paper pick up roller not grabing the paper (clean or replace it).
If the printer doesn't blink ALARM. check if you have failed jobs in QUE; IF YES DELETE IT AND TRY TO PRINT AGAIN OR TRY UNINSTALL AND REINSTALL THE PRINTER DRIVER.
Dec 11, 2014 | Kodak ESP3250 All in One Printer
Printer screen wont turn on and alarm light on.
Check the print head. Get a cloth and clean out the print head area.
Aug 28, 2014 | Canon PIXMA MX310 All-In-One Printer
The orange alarm light in on. Nothing else is happening
This error means that some mechanical parts of your printer is in trouble. This could be some of the causes:
1. The print head is stuck somewhere or is unable to move because of some blockage in the printer's bay.
2. If you are using a Continuous Ink System, then the tubes might have blocked the print heads from moving.
To resolve, turn OFF your printer. Remove such blockage then turn the printer back ON.
Oct 26, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Printer Won't Print
Follow the link below for what the lights on the machine mean. I know that if your alarm and data light are on it means the toner is empty, and you wont be able to print, you would need to replace the toner cartridge, please follow the link below.
Apr 17, 2010 | Brother HL 1440 Laser Printer
Won't print
Turn the printer off.
Wait 20 seconds.
Turn the printer on.
Lift the cover -- hopefully, the print-head will move to the position where the cartridges can be accessed.
Remove one cartridge.
Re-insert that cartridge.
Close the lid.
If you still get the "blinking", re-open the lid, remove the other cartridge, and re-insert that cartridge.
Otherwise, see: and enter your model-number, and download the manual (PDF) and follow its directions, or read the online-help for your specific PIXMA.
Apr 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
Aug 25, 2009 | HP LaserJet 2200dn Printer
Have just changed refilled cartrige, alarm light is blinking
The printer does a longer green flash and then the amber flashes. you need to tell me how many flashes between the green flashes, to know what the problem is.
Aug 13, 2009 | Canon PIXMA iP1600 Printer
Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer Alarm Light
Your carriage motor could be the problem.
Nov 20, 2007 | OKI Pacemark 3410 Matrix Printer
Printer alarm Brother 1440
Use the following steps to perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
let us know if this works.
Oct 29, 2007 | Brother HL 1440 Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
73 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
