Question about HP Color LaserJet 5m Printer
My printer is coding a 50.2 fusion error. Do I
My printer is coding a 50.2 fusion error. Do I need to replace the pc and if so where is it located in printer?
    President:
  • 2,306 Answers
That is a fuser error, probably need to replace the fuser and it's the hot unit in the back of the machine, the last part before the paper exits.
Posted on Sep 10, 2009
Testimonial: "thank you very much!"
    President:
  • 1,653 Answers
If a 50 SERVICE error message is displayed, turn the printer OFF for at least 10 minutes. Failure to wait the full 10 minutes before turning the printer ON results in a continuation of the error message and the shutting off of the fuser lamp current during this time, though the source of the error may have already been resolved.
If this does not resolve the problem then you will need to have the unit serviced professionally as there are several possibilities to check and possibly replace to cure the problem.
If you are competent with electronics and testing drop me a note to kw7157@yahoo.co.uk and I can give you much more info relating to this issue that will not fit in the space allowed here. This is not for someone that does not know what to do and parts are not cheap and getting harder to find for these older models.
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
Mar 17, 2014 | Brother DCP 165C Compact Color Inkjet...
HOW CAN I SOLVE ERROR CODE E000007 0001 IRC 5185
Fixing belt home position detection error.
Replace Home Position sensor - 0,001%
Replace the Fixing unit - 105,9%
Feb 11, 2013 | Canon irc5185i
Ricoh 410 DN SC545 error code
This is a code for fusion.
Check:
- Thermistor
- Thermostat
- Lamp
Dec 30, 2010 | Ricoh Aficio SP C410DN Laser Printer
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
Printer fails to print - error code -50
From System Preferences / Printers, delete the printer completely.
If you have the driver installer for the driver you are using, re-launch it and choose the "uninstall" option. If not, you will have to rip out a lot of code by hand -- you will have to search HP's website for the page on how to manually remove traces of old Mac HP drivers.
Download the latest driver for your printer from the HP website. Install if carefully.
After rebooting, go to System Preferences / Printers and re-define the printer. Make sure you use the HP driver, not any of the generic drivers.
This ought to clear the problem.
Jan 29, 2009 | Computers & Internet
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Error 50
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Jun 19, 2007 | Brother HL 1430 Laser Printer
HP Color LaserJet 5m Printer Logo
298 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
