Question about GE Profile¿ 42" Built-In Side-by-Side Refrigerator with Icemaker, PSB42LGR
Freezer door hard to open for about 3 minutes
Freezer door hard to open for about 3 to 6 minutes after closing. It feels like a vacuum is being sucked in the freezer. After it sits for a few minutes, it will open normally. This unit is a GE Profile PSB42.
    President:
  • 1,653 Answers
This is normal and nothing to worry about. The warm air that enters the freezer when the door is open simply cools and causes a pressure drop in the freezer whioch makes the door hard to open for a while until the pressure equalises. It at least proves that you have good door seals!
Posted on Sep 10, 2009
Iam amazed that on the entire Internet there has never been a ccorrect response to the question of why the freezer door is so hard to open after closing it intitally. Granted, I have just had a rather large martini, wine with supper and am now sipping cognac from a crystal snifter, I will state a brief fact. Take a mirror and look at the bottom of the freezer door; there, you will see two strange looking ducts, called vents. When the freezer door is closed, the interior air is pushed from the interior of the freezer, and it exits via those air vents. The check valve in the vents prevents air from rusing back into the freezer. Hence, the vacuum effect. I had a problem with my White-Westinghous freezer having frost buildup in a frost free freezer, so, I spent $150 on a new door gasket, only to find out that the replacement gasket weighed 6 oz. less than the original. was not as stout, and could not be snugly fit, even using a heat gun. I returned the gasket for credit, and, after replacing the two vents located at the bottom of the door, my freezer funcioned perfectly.
Posted on Sep 09, 2011
I have problem with m refrigerator door.As soon as I open the door,after closing it,I can not open again.I have to wait 4-5 minutes to poen it again. It seams to be stiked to to the refrigerator.Please...
Is the same thing happening to the freezer? There may be a vacuum being created like a suction cup, in your fridge due to the high quality seal you have... your door becomes hard to open... maybe try closing it slower/softer or place a "small" flat fridge magnet on the TOP of the door where the seal meets it, to allow for a small amount of air to prevent the suction. Good luck!
Jul 24, 2011 | Refrigerators
Freezer door "locks" or is hard to open, if opened a few minutes prior?
This is normal. Freezers have a vent port to let high moisture out. When you open the door moisture laden air enters. When the door is closed the hot air from outside expands and leaves through the vent port. This creates a vacuum in the freezer that lasts a few minutes. No problem
Sep 16, 2010 | Sub-Zero Freezers
Sub zero freezer door no longer vacuum seals when the door closes. There is nothing obstructing the door.
Make certain that the freezer fan motor is operable. Otherwise, contact an appliance service company.
Feb 20, 2010 | Freezers
Sub Zero Model 550 (1992) freezer drawer doesn't seal
the drawer need to be adjusted so that it will close.. with a air leak you will have frost build up around the drawer...there are drawer closers on the back of the rails... it may be broken or just pushed the wrong way...when the freezer is cold it should make that sucking sound and be hard to open ... hope it helps
Sep 19, 2009 | Refrigerators
Hissing
not to worry the warm air gets in when you open door then it cools and makes a vacuum and sucks air in...thumbs up
Aug 09, 2009 | Frost Freezer WCWO F15WA FREE - POCKET...
Not sucking out air when door closes anymore
run your hand around the freezer gasket with the freezer closed slowly and see if you feel any cold air,also check corners they leak to,frost is caused by warm air getting into the freezer or the defrost system is failing,let me know what you find-mike
Oct 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Doors not sucking closed
This is not a fault but it is a design problem that cannot be resolved, the problem occurs because between the fridge and the freezer there is an air duct to allow the freezer air to be blown into the fridge however when you close the fridge door this forces the air back into the fridge, the result is that it is forced into the air duct and pressurises the freezer or visa versa and pops the door open to allow the compressed air to escape. soory no cure to this one. Regards Advisor
Sep 01, 2007 | Kenmore 64702 Top Freezer Refrigerator
GE Profile¿ 42" Built-In Side-by-Side Refrigerator with Icemaker, PSB42LGR Logo
994 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
