Question about Garden
Does'seem to be getting gas,fuel lines are clear and will start using ether .Ran for a awhile when I first got it.Spark is good.Carb does not appear to be pulling gas from the tank.Full choke does not help.
  • 388 Answers
Well since you didn't list the make, model or engine size the only thing I can come up with is get a kit to rebuild the carburetor or order a new carburetor and gasket kit.
Posted on Sep 10, 2009
  • bulldogchief
    bulldogchief Sep 10, 2009
Ice auger isn't getting gas....
You will probably have to remove and disassemble the carburetor. Clean thoroughly and reassemble. Drain the gas line until fresh fuel comes out. Always run premium nonoxygenated( no ethanol ) fuel in your auger and add a fuel stabilizer like stabil or seafoam .this will help keep the problem from reoccurring. Hope this helps.
Jan 12, 2014 | Motorcycles
Ran snowmobile out of gas now wont start
try a couple of shots of Ether to get the Air out of the Line between CARB and Tank, seen it a few times also it will clean out the Jet in the Carb , put some Injector Cleaner in the tank to get rid of Varnish IN the Carb should take a few tries but within Half hour should run like New
Dec 17, 2013 | Cars & Trucks
Cr 250 r honda dirt bike wont start
What did the spark plug look like when you first took it out? Was it black/wet/sooty or was it a light tan/gray color. If it was black/sooty, then I would guess you need a coil. I know you said it had a good blue spark when you checked it, but if you poured a little bit of gas in the cylinder and it still wouldn't fire that would be my first place to check. If it ran briefly after you poured a bit of gas in the cylinder and then died, then it's a fuel supply issue. Remove the line that goes from the gas tank to the carb and make sure you have gas at the carb. If you have gas, then I would remove the carburator and take it apart making sure all the jets and passageways are clear. Use carb cleaner and an air attachment and if you still can't get it out, use a small wire to clear things up.
Reassemble and it should run, otherwise report back and we can go to the next step.
Jul 11, 2013 | Honda Motorcycles
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
My weedeator BV1650 ran fine until the fuel line cracked. I've replaced the fuel lines and primer bulb but now it won't start. It will run on a small squirt of ether then nothing. Seems like its not...
First ting is check yr. kill switch. Is it off or shorted out? Clean the carburator. It probably is gummed up with old fuel. You should also check your plug and coil by pulling the plug to see if it makes a spark. Also check your magneto for surface rust. Lightly sand any off. If it doesn't run after that, buy a new one. Good luck
Feb 18, 2018 | Poulan Garden
Husqvarna 51 died and wont restart
hi
if you have a good compression,a strong enough blue spark and carburetion for the fuel air mixture try priming the engine(put small amount of gas in the spark plug hole)then start the engine.If the engine runs only the gas you put inside the cilinder there is a carburetion problem to find and fix.
let me know regards savumihai71
Apr 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Wont start acts like no spark but is getting spark
Did you try pulling the spark plug and spraying some starter fluid or carb cleaner into the cylinder, putting the spark plug back in and starting it? If you've got spark and it doesn't start for a few seconds then you probably have carb problems. Good luck!
Mar 06, 2010 | Karcher G3025OH Pressure Washer
Lawn Tractor won't start after wrong fuel used, drained, etc
Check the fuel shutoff solenoid (on the bottom of the carburetor -- has a wrie plugged onto it) -- it may be sticking.
Spray carburetor with carb cleaner. Then if you can get it to run long enough to do any good, put carb cleaner in the fuel -- follow mixing proportions on the label.
If this doesn't work, need to take carb apart and thoroughly clean it.
Charlie
Aug 29, 2009 | Garden
My 80 ford f150 v8 302 wont start up i
if this is a 1980 F150, emissionwiz is correct in saying it has a carburetor, if your engine runs on ether, you do not have fuel supply to the engine. Check fuel delivery at the front of carburetor, should be a line screwed into the carb, may be connected by a rubber hose, remove this line and crank engine, look to see fuel is gushing out of the line, if no fuel the pump is bad, check fuel lines back to pump for leaks, replace leaking lines if necessary. If you get fuel then your float inside the carb is stuck, and the carb will need some attention, hope this helps, let me know
May 30, 2009 | 1989 Ford F 150
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
