Question about Gaggia Titanium Espresso Machine
The steam function has stopped working, I regularly descale, but it just stopped working all of a sudden. Any ideas how to fix it?
    President:
  • 1,618 Answers
Try this, using a paper clip make sure that the end of the wand is not clogged. If not then open steam wand and then push the knob in, if that works then the valve stem needs to be replaced, if it doesn't, can you get hot water from the valve, if yes then the thermostat or the element on the steam booster boiler is damaged.
Posted on Sep 17, 2009
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Oct 19, 2014 | Gaggia Titanium Espresso Machine
Why has the steam function has just stopped working - power on but nothing happens
My wife has one of these irons and she loved it. Now it steams for a while, and a red light starts blinking and it stops steaming. It can be turned back on and works for a while, then the same thing happens. I read that it needed descaled, so I bought OUST descaler and ran it through the iron, but it did not solve the problem. Any one have a solution to this problem, I would like to hear from you.
Jul 07, 2014 | Rowenta DG8430 Pro Precision Steam Station
Our saeco talea giro descaling light is on and after a full descaling cycle it remains in the descaling mode. any ideas? thanks
To remove a descaling light you need to hold down the steam/water button for 6 seconds and the light should go off. The button is located on the right side of the coffee button.
If you are in need of the manual you can download it here
May 10, 2011 | Saeco Talea Giro Espresso Machine
STEAM FUNCTION STOPS WORKING
You need to replace the descaling resin. I have no idea where to find it, however.
Dec 06, 2009 | Irons
Doesn't produce steam for more than 1 minute.
You should not have your steam wand on for more than a minute.
Jun 29, 2009 | Gaggia Carezza Espresso Machine
Saeco wont stop descaling, i have yoused 2 cleaing solusion and the mashine just right .. descaling cycle interrupted turn machine off .. wenn you turn machine off and start again then it start descaling...
In service menu there are 2 parameters you should look. First one - descaling - should be on 'done'. The second one is a counter - water used since last descaling - should be on 0.
Jan 16, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Tefal Pro Express Steam Generator Iron
Irons are generally not worth repairing. That said, try to clean out any mineral deposits with a mixture of 1/3 vinegar and 2/3 water. Put in the usual amount. Warm the iron, try to get steam. Empty the iron and do it twice more. Then, rinse it out with plain water.
You may get lucky!
Jan 21, 2008 | Irons
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
211 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
