Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
My phone isn't charging, i have tried two different chargers for the samsung tocco but it still doesn't charge...any suggestions to why this is as i currently cannot use my phone?!?!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 93 Answers
It appears like your battery has gone. Try with a new battery. Best thing would be getting the battery checked up at the service centre.
Posted on Sep 11, 2009
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
The charger is not working
Try setting your phone in a different position while it is charging. The wires on the charger (the part that touches the phone) may be off a little, so resting your phone in a different position should help them to touch and charge your phone. If that doesn't work, I'd suggest buying a new charger.
May 13, 2011 | HTC EVO 4G Smartphone
Where can I buy a circuit board for samsung f480
hi i have samsung f480 touch mobile phone .it was not charge diret charger. i use only multi charger.so ineed soiution for direct charge . service tech person said the board problem.
Mar 10, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
My tocco does not turn on att all , no life, i press the power button and nothing happens , no matter what i try the screen doesnt come up :(
It sounds like you may have a battery or charging problem.
If you use a home charger try using a car charger to see if your home charger has become defective. Same if you use a car charger - use a home charger.
If neither charger charges the phone:
1) Take the battery out of the phone.
2) Look on the battery and locate the connector(s) that provide power from the battery to your phone.
3) Take a pencil eraser and (gently) use it to clean these contacts.
4) Replace your battery and turn your phone on.
If this doesn't work, take your phone to your cellular provider's service center to have the battery checked.
Note: Battery's purchased on the retail market can cost up to $50.00. However, many batteries are sold on eBay for less than $7.00...
Jan 26, 2011 | Samsung Tocco F480 - Pay Monthly Cellular...
Tocco F480 battery charging problems
i have had the same problem - try adjusting your display settings - if they are on the brightest and longest setting - go to settings and then dispaly and light setting and adjust them them - the battery life was really short (less than a day) i have changed all of my setting to a lower setting and now it lasts for days!! - really simple but it works ! :)
Jan 26, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
The phone will not charge
Try replacing the battery for $10-20 bucks. If that doesn't work consider having the phone worked on. Also, double check and see if you have insurance on your phone. Finally, If the cost is to high you might consider getting a new phone. Here is an excellent resource for new cell phones, they have great customer care and offer a very wide selection of the most popular phones from the major carriers. Get the insurance with every cell phone purchase in the future, it's worth it.....
http://shop.acnwireless.com/mobile/?r=acn&eid=01958203
Sep 01, 2009 | Samsung Tocco Ultra Cell Phone
Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Apr 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Tocco not charging
its your pins inside your phone that connect your charger to the phone probably bent them they are **** happend to mine and they said as they are bent its my fault lol and samsung wont repair under warranity
Oct 12, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung tocco
To the person who wants to change the language....menu---settings---phone settings---language.
for every1 else, have you tried car chargers?? my old phone never worked on mains charger, but for some reason it worked in the car!! they normally come with warrenty so you can get them repaired for free that way, but there are people on the internet or samsung themselves that specialise in fixing these phones x
Sep 28, 2008 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
112 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
