Question about McCulloch 10" Electric Pole / Chain Saw
How to remove clutch. McCulloch 438 chainsaw. This required to get access to chain lub system. Thank you, Michael.
    President:
  • 2,220 Answers
I think its an outboard clutch, use this as a guide. A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I cannot find an IPL for your saw, it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
Posted on Sep 10, 2009
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
Why would the rope slip when you pull it the rope to start my mcculloch chainsaw but it does start
the starting clutch is slipping , this is not to be confused with the chain clutch (other side) reasons a start clutch slips , dirt inside /broken friction surface
May 22, 2014 | McCulloch Garden
Chain oiling
yuo need to remove chain and bar.then remove clutch,remove flat plate covering oiler. NOTE:some saws requier a special tool to remove clutch left handed threads inspect oiler .sometimes the sawdust and dirt can be cleaned out and it will start workin again. and sometimes not
Oct 25, 2012 | McCulloch Garden
Silver Streak chainsaw bar and chain
Replacement Silver Streak Bars For McCulloch Chainsaws Find your Chain Saw model, then click on the link to get the ChainSaw Bar and Chainsaw Chain for each model!
Special! Get 30% off when you buy bar and chain together!
http://www.jackssmallengines.com/chainsaw_bar_silver.cfm?manu_name=McCulloch
Jul 19, 2012 | McCulloch Garden
How to remove the chain on a Mcculloch MS1435? I can't get it over the 'clutch/sprocket' assembly. Do I need to remove the clutch?
There should be need to remove the clutch, push the bar back s far as it will go, un loop it off the nose of the bar, the bar will then come away making it easy to remove the chain.
Jun 27, 2011 | McCulloch Garden
How do you change the chain on a mc culloch
Visit this site and download the user manual. It will most likely require you to remove a couple screws and the chain guide.
http://www.mccullochpower.com/node7877.aspx
If this was helpful please rate/vote me. Thank you.
Mar 01, 2011 | McCulloch Garden
Need owner's manual for pro mac 1010 McCulloch chain saw
I have just scanned my own manual as a pdf, not sure how to attach it though ! Regards, Michael
Feb 27, 2011 | McCulloch Chain Saw Sprocket Fits...
Mcculloch 14" chainsaw no oil at chain??
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 on a McCulloch it is most often a plugged or disconnected hose.
There are in excess of 230 different McCulloch chainsaws. Oilers are often specific to one model. Please reply below with the model and serial number of yours so I can provide a more complete answer and an IPL. HTH
Lou
Jan 22, 2010 | McCulloch Garden
McCulloch 10" Electric Pole / Chain Saw Logo
969 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
