My Computer restarts continous.
If i start my Windowx XP Home in normal mode. I see the Windows icon with a Process Bar. The i'll see a black screen and the PC restarts again and again. After that i started windows xp in safe mode and can see the an error message that d347bus.sys cant load. I hit Esc and my PC restarts.
    Sergeant:
  • 161 Answers
A file on your system got deleted.
Easiest way to fix that would be if you have a friend or yourself having a computer with XP Home.
What you want to do is take out the HD (hard drive), while doing so be sure to wear wrist straps so you don't fry your computer chips. That or be careful when touching parts of the computer, due to electrical static.
Place the HD in the new computer as a Slave Drive. When doing this, be cautious because the pins are fragile. Also remember to move the little black tab from "master" to "slave".
Boot up the pc.
Once the pc starts it will try and fix your lost file through a recovery. Once it done, shut down the pc. Unhook everything and put the HD back in your pc and you should be working again.
If you have more problems msg me again.
H
Posted on Sep 10, 2009
  • pickmynose Sep 10, 2009
    Here is a link that might help you with images.
    http://www.dtidata.com/resourcecenter/20...
    Scholar:
  • 146 Answers
Sounds like you have been infected with a trojan of some sort. You can try do one of two things. Either re-install your OS or attempt to get around the trojan by doing a system restore at a time when you know your machine was working properly. Forget trying to cleam it out, I 've found that once you at this point, you need to be drastic in your fix.
If you chosse to attempt a system restore boot up in Safe Mode, just prior to it completing its start up, you will see a window with asking you if you ar egoing to do a system restore or if you want to just complete your start up in safe mode. You will be given a yes/no choice, click no which will result in bringing up the system restore window.
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
The computer froze up; I attempted to restart it but it got no further than the Windows logo. I then took the battery pack out and put it back in. Then a screen came up that said that Windows had failed to...
No, it is not hopelessly broken. I would suggest this:
When you start it, get into safe mode. Do this by tapping on the F8 key soon after you turn it on. When you see the white menu on a black screen, choose safe mode and let it start. Once it starts, you can do the troubleshooting. In your case, I would suggest doing a system restore back a few days when you know it was working.
That should do it.
Apr 15, 2011 | Toshiba Computers & Internet
When the computer boots, the loading Progress Bar of Windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black.
Welcome to FixYa
Dear user
This might be Hardware or Software Issue.If you have installed any New Hardware of Software Simply Remove it .And Try to Boot.In case of Software,Try to boot in SAFE-MODE by pressing 'F8KEY' when booting time to Enter SAFE Mode...After Entering Safe mode You can Uninstall newly installed Softwares.It might be reason for Clash in windows system Boot file.
Let me know if you need Further assistance...Hope this Helps...Thanks for Connecting FixYa,,,
Apr 15, 2011 | Office Equipment & Supplies
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Repeatedly restarts after Windows loads
NEED HELP SETTING UP WINDOWS XP . MY WINDOWS IS NOT LETTING MY ICONS UP ITS SAY ACTAVITE WINDOWS
Oct 05, 2008 | Microsoft Windows XP Professional for PC
An error to my microsoft
Try putting the computer into safe mode.
To do this shut the computer down.
As the computer gets ready to start booting up, hold down on the F8 key.
At the menu, move the arrow keys on your keyboard to safe mode and press enter.
Once Windows finishes booting up in safe mode, restart the computer in normal mode.
This can repair the message.
Jun 13, 2008 | Microsoft Windows XP Home Edition
KDS Valiant no image on on screen
first of all try to start your laptop in safemode
1 start laptop
2 continously press F8 key
3 when you see menyu select "start windows in safe mode"
if your computer starts with same mode and you see the desktop
then you just have to restore your xp with earlier system restore check point
and if you dont see desktop in safe mode also then you must have to install win xp again
steps for restore windows xp
1 start
2 programs
3 accassories
4 system tools
5 system restore
6 chose restore system to earlier time
then select any earlier date in calender at which computer is working properly
and click restore
it restores your xp and restart your pc and your problem will be solved
if still having problem then you must reinstall windows xp
Mar 07, 2008 | KDS Valiant 671DP Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
