Question about Toshiba Office Equipment & Supplies
Toshiba e-studio 230 Code F103
I have problem with my copier machine ''call for service'' I tried to press C & 8 I got the F103 code so is that mean i need to format HDD if that what i need how can I format HDD for toshiba e-studio 230 please i need the instruction
  • assiegh Sep 12, 2009
    thank u for posting solution, so when I replace the HDD should I install software to the new hard drive
  • Toshiba Master
  • 13,433 Answers
F103 is a hard drive time out - this could mean that the hard drive is not responding - has failed, so formatting may not help and the whole drive may need to be replaced.
Posted on Sep 12, 2009
  • Ekse Sep 12, 2009
    I would recommend getting toshiba to fix your unit, if you wish to repair it yourself you can purchase a service manual for the machine from http://www.service-docs.com/store/search...
    it is halfway down the page.
    TOSHIBA e-Studio (eStudio) 200L, 202L, 203L, 230, 232, 233, 280, 282, 283 Series
    Includes all of the following:
  • e-Studio 200L, 202L, 203L, 230, 232, 233, 280, 282, 283 (DP-2020,
    DP-2050, DP-2320, DP-2330, DP-2340, DP-2820, DP-2830, DP-2840) Service
    Handbook
    (DP-2020, DP-2050, DP-2320, DP-2330, DP-2340, DP-2820, DP-2830,
    DP-2840) Service Manual
  • e-Studio 200L, 230L, 280L Parts List and images
  • e-Studio 202L, 232, 282 Parts Manual
  • e-Studio 202L, 232, 282, 203L, 233, 283 Parts List and images
  • e-Studio 230, 280 Parts Manual
  • e-Studio 202L, 232, 282 Parts List
  • e-Studio 202L, 232, 282 PC Board Repair Manual
  • e-Studio 200L, 230, 280 PC Board Repair Manual
  • eStudio 200L, 230, 230L, 280 User Functions Guide
  • eStudio 200L, 230, 230L, 280, 280S Imaging Manual
  • eStudio 200L, 230, 280 Basic Function Operators Manual (UK)
  • eStudio 200L, 230, 280 Basic Function Operators Manual (US)
  • eStudio 202L, 232, 282, 352, 452 e-Filing Guide
  • eStudio 202L, 232, 282, 352, 452 Network Administration Guide
  • eStudio 202L, 232, 282, 352, 452 Network Fax Guide
  • eStudio 202L, 232, 282, 352, 452 Printing Guide
  • eStudio 202L, 232, 282, 352, 452 Scanning Guide
  • eStudio 202L, 232, 282, 352, 452 TopAccess Guide
  • eStudio 202L, 232, 282, 352, 452 User Management Guide
  • e-Studio 200L, 202L, 203L, 230, 232, 233, 280, 282, 283 Technical Bulletins
What does call for service F 070, in toshiba e studio 230, refer to ? How can I solve the problem?
Toshiba Studio 230 Error Codes
Toshiba e-Studio 230 Error Codes Code: F070
Code
F070
Description
Communication error between System-CPU and Engine- CPU
Sep 30, 2016 | Toshiba E-studio 230 Multifunction Copier
Code call for service
so,call for service,they dont put that there to just look at it
Jul 01, 2015 | Toshiba E-studio 230 Multifunction Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
What is the service code
There is no service code.
To reset the copier press and hold 0,8. button and switch on the copier.
enter 690 press start button
enter 2 and press enter key on touch screen.
once the reboot massage apears switch off the copier and switch on.
Mar 29, 2014 | Toshiba E-studio 230 Multifunction Copier
Signal f103
You have a corrupted hdd promblem on you toshiba. You should find another hdd and the firmware and make them using usb stick
Jan 03, 2014 | Toshiba e-Studio 232 Black and White...
Code c 440
Try press number 0 and 8 meanwhile power ON machine. After 3 sec, release the number. Press 2002 > Start > 0 > Enter. Reboot machine. Good Luck
May 17, 2013 | Toshiba E-Studio 456 Copier
What does error message F103 mean?
Hello
Before we start to get the machine into the test mode, switch off the machine while holding down 0+8 buttons switch the machine on and then input 694.
The error that you have is explained below.
[F103] HDD transfer time-out.
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of the harnesses are broken.
(3) Perform the bad sector check (08-694)
(4) If the check result is failed, replace the hard disk drive.
Regards
May 11, 2011 | Toshiba e-STUDIO 352 Black and White...
Toshiba e-studio 45call for service 254292
Press "clear/stop" and "8". While holding this combination of keys down, an error code will be displayed....what code are you getting?
Sep 15, 2009 | Toshiba e-Studio 45 Black and White Copier
Display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Jul 28, 2009 | Toshiba e-Studio 232 Black and White...
F103 ERROR CODE IN TOSHIBA E-STUDIO 282
F103 indicates HDD transfer time-out.
U can try format the HDD (08-690).
Then u perform the bad sector check (08-694). *take long time
If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
* replacement of HDD require firmware update
Jul 02, 2009 | Toshiba e-STUDIO 282 Black and White...
1,600 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
