Question about Air Tools & Compressors
I have a 1.6 hp 26 gal craftman air compressor just bought it and took it home... it was a floor model.. Well I pluged it in and it ran but didnt build up air (my air gagues didnt move) is there something i have to turn or loosen to build up air?
  • bulldogchief
    bulldogchief May 11, 2010
    Is there a sound of rushing air coming from teh compressor when it is running?
  • 530 Answers
You stated that it did run so the air had to go some where. Did you hear anything leaking and how long did you let it run for? It should take about 12 to 15 minutes to fill.
Let it run for 5 then shut it off. If there are any leaks you should be able to hear them clearly. If you don't hear any, pull the ring on the safety release valve located on the switch. If there is no air released from the safety valve. Then it's possible that the check valve in the manifold is frozen. You should be able to get a replacement from sears. If there is air then it's probably just a bad tank psi gauge.
Please let me know if you need any more help with it.
Posted on Sep 10, 2009
What kind of oil do i need for a craftman 1 hp 3 gal 125 psi compressor m/ n 921 153101?..
For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
Oct 03, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
25 lb oil free air compressor craftman not building pressure
most likly the regulator is no good, some can be serviced, some are sealed units.
Mar 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Need a price on a air compreser 1.5 hp 3 gal 125 psi craftman air compreser no.15310
when you go have a look on alibaba.com and search for 1.5 hp, 3gal you will find chinese factories who make your type of compressor. when you order a whole 40ft container they will cost you abou 50 bug or less. as you can see it is very diff to give a raisonable price for such machines. when you look on the national market with the same search words you find several onlineshops and the price will be a lot higher, its a hard question you ask. greetings.
Feb 19, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor won't build psi above 30,is this typical of the regulator or pump? the compressor is a 3 gal craftman about 1 yr old.
sounds like the regulator is faulty, normal running air should reach 110 psi, this will allow you to run tools...
Jan 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a craftman oiless air compressor model # 919153210 that I need parts for and sears do not carry the part anymore. thank you for any help., gcmac@netzero.net
Many of Sears oilfree compressors were made by Devilbiss. Try going to this address http://www.devilbissparts.com/ and enter your sears part numbers. (example cac-4281 for valve plate) They will most likely have the parts that you need. Good luck and email if you have other questions about your conpressor.
Feb 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
71 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
