Question about T-Mobile Sidekick® 3 Cellular Phone
Keyboard Sidekick Slide
Any time i type the letters M, O, P, or the #9, or the question mark on my key board i get this .. zvm 37oeudj 48prifk 159qtagl xb, --(in order). when im in my email and i type the letter M, it jumps to my pic albums to attach a photo. and when Im on the web browser and type the letter M, it goes to the previous page. What the hell is going on nwith my phone???? can anyone help??!!
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
Letters i type on key board come up as different letters on paper. example if i type the word see, it comes up and types j;;.
On the L. side of the keyboard is the pitch slide switch it should be in 10 or 12 not PS.
DickyO
Aug 16, 2011 | Swintec 7040 Typewriter
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
In my key board m button tyed show 0 why
You probably have Number-lock active, test and see; u = 4, i = 5, o = 6, j = 1, k = 2 and l = 3.
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
When I type 0 9 numbers are coming up instead of letters problem:
If you had specified exactly what computer you have I could have give you exact instructions ;) Here are general instructions that should help with this problem.
Look around your keyboard, see if you can find a key marked "Num LK". If the Num LK text is the same colour as your other keys, just press it once. Try typing, see if that helped.
If the Num LK text is blue, Look around your keyboard, see if you can find a key marked "Fn". Hold the Fn key pressed while pressing the Num LK key once. Try typing, see if that helped.
Good luck ;)
Feb 02, 2011 | Acer Computers & Internet
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Keyboard
I WANT TO BUY ANOTHER KEY BOARD. WERE CAN I GET
ANOTHERE SIDE KICK 2 KEY BOARD AT .
Jan 22, 2008 | T-Mobile Sidekick II
Keyboard does not work
don't think this is caused by the game install shut down the pc and remove the battery and charger for a few minutes. Boot it and try again try connection an external keyboard
Sep 11, 2007 | Gateway 2520915 Keyboard
T-Mobile Sidekick® 3 Cellular Phone Logo
139 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
