Hp xg836 updated memory and system does not turn on, entered setup and shows the new 256 memory in bank one and two total 512.. system does not want to start. When i remove one bank and install the original 64 that the computer came with and it works... what am i doing wrong..
  • hmorim Sep 10, 2009
    cleared cmos and still no go
    I have xp running, what i don't get is when in have the original 64 in bank 1 and one of the new 256 in bank two it show up as 320. this is computer i just took out and dusted off i'm trying to set up for my 7yr old ... do you know where i can find the motherboard config, it's congnac motherboard
    Sergeant:
  • 244 Answers
Probably wrong buss speed or memory configuration. may need to have HP specific RAM. the older machines can be rather picky about 'proprietary' Ram configuration. have an older Compaq laptop that accepts (it fits in the slot), from a Dell laptop, but doesn't like it!
Boot-up shows it as extra Ram, but shut down gives me weird vertical colored bars and i have to shut down manually. you may want go online, if you can, and order HP upgrade Ram for your desktop. perhaps you should replace your system with a newer desktop! sounds rather old to me! no offense- we make do with what we have! my first computer was a commodore vic20- 1981! then a c64- much better for the time-1982- then a c126- 1984. then Dos 1.0, Dos 2.0 Dos 3.0 Dos 6.6 windows 96, etc. even had Pong, Atari, NES (love dragon warrior 4) now p4 toshiba satellite-keyboard sucks!!. laptop. my wife has a desktop 3.2 G CPU 2G Ram .at least i'm portable!
So, consider an upgrade. check E-bay, or Craigslist.com.
what OS are you running? Win98? 2000? ME?
Posted on Sep 10, 2009
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
I have a Easy Note M5 280DW and would like to know if I can upgrade the RAM?
Standard Memory 256 (256MB x1 Removable) Maximum Memory 1 GB The standard memory of your system is 256 Mbytes and the maximum memory it supports is 1 Gbytes.
So you can either upgrade the RAM by adding 1 stick of 256 Mbytes (for a total of 512 MB) or buy two sticks of 512 Mbytes each (for a total and maximum memory of 1 Gbytes).
You are looking for PC2700 DDR Memory.
In any case, check the memory you have installed.
You can download a free utility like CPUZ that will give your information about your system, including the number of memory slots available and used and the memory (amount and type) installed: http://www.cpuid.com/download/cpuz/cpuz_152_setup.exe
Aug 03, 2009 | Packard Bell Computers & Internet
I installed another 256 of ram, for a total of 512, but the computer only says i have 256 what can i do.
I've done this before in my early days. Make sure that the memory is exactly the samme type as the original one, and make sure your motherboard can handle the extended memory. Check in system properties for all this info.
Jun 22, 2009 | Dell OptiPlex GX150 SF PC Desktop
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Adding memory
Try re-seating the RAM. If that doesn't work ensure that your laptop supports the ram you bought. If the RAM you have is PC2700 and your computer only supports up to PC2500 (for example) it wont work.
Aug 19, 2008 | Sony VAIO FRV25 Notebook
MEMORY UPGRADE
Sorry for the delay in my response.
Your computer will accept a maximum of 1 GB of memory. If both memory modules are the same brand and part number then it is possible that one of the sticks are bad.
Try each 512 MB memory stick in the first memory slot, without installing a second stick. This will troubleshoot to find out if one of the 512 memory sticks are bad. If both check out ok, then the problem is with the video adaptor.
Have you tried adjusting the refresh rate on the monitor as I described in my first response?
My final possible solution would be to upgrade the bios. Below is a link to the webpage for your computer system. You will find links for troubleshooting guides, driver and software downloads, product specifications, etc. If you click on driver downloads, then choose your operating system, you will be directed to a page that should provide the latest ROM (bios) update.
http://h10025.www1.hp.com/ewfrf/wc/product?product=93322&lc=en&cc=us&dlc=en&lang=en&cc=us
Jul 28, 2008 | Computers & Internet
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
