Question about Shimano Ultegra 8-speed Bar End Shift Levers
A piece of old cable that snapped off is stuck inside and will not allow new cable to sit right i need schematic or info on how to take apart so i can remove pieces of frayed cable
    President:
  • 1,137 Answers
Check this site out:http://www.parktool.com/repair/readhowto.asp?id=117 Lots of good articles and pictures.
Posted on Sep 11, 2009
Do not know how to put the razor heads on after cleaning
most simply snap on. i sit with elderly and have to clean these all the time. the small pieces inside come apart, but you simply put the round pieces back in first, thenthere should be a bigger piece to fit over all three small round pieces. simply line it up over the 3 round pieces, and turn slightly clockwise and it should click. once that is in place, simply take the two hinged looking pieces and push into the device where they line up, and it should just snap in place.
Nov 19, 2012 | Health & Beauty
What is a possible list of causes that could come from the driver side door not opening at all in your 1993 Buick Regal?
Door mechanism came apart inside the door. This can be a real pain if you cannot open it at all. You will need to take out all of the screws inside door handle and behind it. Pop out the plastic holding pieces that keep the door trim stuck to the metal part and pull the trim up and over a little bit to try to get to the linkage and get it open. Then you can pull the trim up quite a bit and see what linkage came apart and try to snap it back together and/or replace the linkage. Have you tried to open it from getting inside it? Sometimes when the linkage fails you can still open it from either side. Hope you get it going with this info and thanks for using FixYa.
Jan 20, 2011 | 1993 Buick Regal
I have a kitchen aid KUDS24SE dishwasher that I believe has a piece of glass stuck in the chopper. How do I get to it? I have the impeller out is there a repair manual online somewhere?
there will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
Rick
heres the link
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS24SEWH5/0593/0130000?searchedModel=KUDS24SE&blt=
Dec 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Sunbeam 5891 Bread Machine The drive belt has fractured. How does one remove the bottom cover? Where may one obtain a new belt?
The upper and lower shell snap together. I removed screws from the bottom and could not separate the shell. I them unscrewed the metal shroud from the inside and removed it. It is a tight fit. You will see the snaps inside. I pushed on a couple of the snaps and the shell came apart. I am sure you will be able to address your issue from there. I am trying to find out why the heating element won't work on my machine.
Dec 03, 2010 | Sunbeam 5891 Bread Maker
I snapped the chain on my 97 gsxr600 and it busted some stuff inside. I need to view a repair manual so I can name the broken pieces and possibly fix it
Go to babbits dot com.
They have schematics for every part and a complete parts list with oem part numbers, so not only you be able to identify it, but you'll also have the part numbers.
Any one can take something apart, putting it back together is the challenge.
The schematics show where evrything goes.
Manuals tell you how to take it apart, and give you a few pictures.
I use schematics all the time, print them right out and keep them reference when i reassemble.
I dont have a manual for every make and model motorcycle dirtbike or ATV, so i just print the schematic and i'm good to go, and im sure you will be to.
Plus the dealers love it when you give them the part numbers.
Nov 16, 2010 | 1997 Bikemaster2008 SUZUKI GSXR600 BIKE...
How do I remove the handlebars on a 1998 HD roadking
Remove the cap in the center of the handlebars and take a look, I'm afraid you will have to take the whole housing assembly apart. It's been a few years since I did ours.
Not so easy, first the head light has to come out, the a 5/16 nut inside the head light housing holding on the trim piece that needs to come off. One that's off the plastic trim piece on ignition need to be pried off "gently", then remove the 2 screws and that cover will come off giving you access to the handle bar mounts. Unscrew the old ones at the headstock and put the new ones on where the old ones went and screw them in at the right spot (where you want them) sit on the bike and hang on to them and do them up "tight". Hope this helps! Good luck!
Feb 22, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
Bonnet cable routing Mitsubishi Evo VI
Your cable is generally sold as a one piece unit...cable inside housing. (same as a bicycle brake cable) Many even come with the release handle attached. Therefore, you simply feed the new one in exactly where the old one went and attach it to the lock mechanism. This can easily be done by attaching a wire to the latch end of the old unit and pulling it out from the drivers compartment, then attaching the new one to the wire and pulling it back through. In that way, you don't need to see it to install it (like snaking a wire through a finished wall, without opening the wall.)
If you do it carefully, it should not be that difficult.
Good Luck!!
Aug 21, 2009 | 1995 Mitsubishi Galant
White screen replacing fliex cord need instrutions
As far as I know no one has directions for this.Your on your own.You need to take all the screws out of the phone.The phone basically snaps together.your going to need a security bit type screw driver to take out the screws.Take the phone to a hardware store or sears and check to see what size the screws are.I believe your going to need a number 7 security bit..some times there called a hex key also.You need to take off the back bottom cover.it snaps on.there are 2 screws under the cover.and there are 2 screws on the top of the phone in the back also.you need to unsnap the phone covers apart.Be careful because there is a separate piece that covers the cable and attaches to the phone.The cable runs through that piece.Your going to have to remove the top screen from the casing.No easy way of doing this. just use a skinny screw driver and gently pry it apart till you can pull it apart.You can see where it goes into the casing.After that you may need to take off the silver metal screen over the lcd screen.You can see the cable attaches to the bottom socket on the far left and the other end to the board for the phone.I think there is a piece also covering the cable or bottom part of the lcd screen. that snaps apart but is hard to snap together again.It's round and looks like one piece,but it's actually two pieces.Since both phones are the same,just use one as a guide how it goes back together.I may have skipped a step or two but that's basically how it comes apart and goes back together.Once you take one apart you can see how it's put together and reverse the steps.
May 31, 2009 | Motorola Mobility E815
Driver door lock shoved inside door. (someone tried to break in) I need a schematic or diagram of the door. How to take it apart, what it looks like inside to try and fix this. Can anyone help?
I had same problem. it was not broken into. the screw that holds lock cylinder in fell out. to get inside door is easy. remove screws around border all sides of door and one in middle near speaker. the gentley snap door away from the two clips on inside and lift up off window opening . peel back plastic and you will see the lock mechanism. if need be ( i had to) you can unplug the automatic locks, window and other electric harnesses attached to door inside cover. the lock cylinder will be in bottom of door w/ a brass hex screw. there is a white piece of plastic insert in the hole of lock mechanism and reattach (snap onto bar). its all easy no schematic needed if you have a lil mechanic ability. good luck.
May 02, 2009 | 2004 Suzuki Forenza
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
Shimano Ultegra 8-speed Bar End Shift Levers Logo
88 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
