Question about Toshiba Satellite M35X-S109 Notebook
Wireless Card? Did this unit come with a wireless card? Or set up to be used wireless?Thanks for your help.
  • 126 Answers
In order to locate whether the unit shipped with a card do the following:
Open System Information via: Start Menu > All Programs > Accessories > System Tools
Expand Components and Select Network and Expand it.
Choose Adapter and scroll to locate Wi-Fi Adapter. many protocols will be listed along with names/models of your wifi and ethernet adapters.
An alternate method would be to open Device Manager and look for the adapters provided under network there. You will see your deivces listed there.
In case there isnt one then you can either get a wifi pcmcia card adapter (provided your pc has a slot) or get a usb adapter.
Posted on Sep 10, 2009
  • 400 Answers
It has buit in wireless:
http://www.dealtime.com/xPF-M35X-S109
My LG LHB975 Theather system subwoofer keeps going on n off when playing music flashing blue slowly
marvinpogno,
Sounds like you having an interference issue. Firstestablish a good connection, then diagnose why the signal is getting lost. You write that the problem occurs whenplaying music, which makes it sounds like everything is fine when playinganything but music.
First establish the connections; press and hold the stop button then press themute button on the remote. Check to make sure all units are operatingwith something other than music. Now to diagnose the issue; what you are using to play themusic most likely is causing an interference that is breaking the wirelesslink. Try something else to produce themusic from, ipod, mp3 player, etc. Don't forget about other things that could cause interference. Microwave ovens, wireless phones, wirelesscomputer router, etc. Hope this helps. Please rate the answer if I was able to help, thanks. -Chris
Jan 09, 2011 | LG LHB975 Theater System
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
2.4GHz Wireless Lan And 5 GHz Wireless LAN
this is usually caused by your router and your wireless network card are not compatible... you need to purchase as well cisco wireless network card adn tehn when you press your wireless security on the router, it will automatically apply all security protocol to the connection.
if you do not want to purchase new card, you always can setup these devices manually,
connect to the router via rj45 cable, establish what protocol, security and transmission method/frequency you will be using, write that down, disconnect the cable, enter your wireless network card settings and apply same settings to your network card, this should solve the problem.
as you did not stated what operating system you are using and what card is in your computer, this is unfortunately best advice which can be given.
how to set up your router, you have downloadable pdf file on linksys site.
Jul 28, 2010 | Linksys Wireless-G WRT54G Router
Soon im ganna kill my self or break my hp compaq tc1100 in pieces okay my friend reformated my pc i've lost the recovery cd therefore i downloaded all the drivers for my compaq on hp website but i dont...
Check to make sure your wireless card is enabled in the BIOS. hit f10 or the toggle switch @ startup. go to Devices in the BIOS and check to make sure both options for your wireless card are turned on. I had this issue with the tc1100 with the 2200bg intel wifi card.
Jun 10, 2010 | Compaq 348348001PANEL Tablet PC
Intel wm3945abg wireless dont conect
Try reset router to factory settings and start from scratch. Uninstall drivers for wirless card and reinstall...
Nov 16, 2009 | Acer Aspire 5610-4648 Notebook
How do i set up wireless internet on my hp pavillion a330n desktop? Do i need a wireless card or is it built in? and where do i put the wireless card if i need one?
Yes you need a wireless adapter.
Solution one : Get PCI wireless adapter which you will insert in an empty PCI slot inside your computer.
Solution 2. Buy a USB wireless adapter, which you plug in a USB port.
However, if my memory serves me right, that particular HP pavillion is 5 or 6 years old, and it does support USB 2.0, just USB 1.1
My advice to you is to buy a USB 2.0 PCI card to be installed in an empty PCI slot )or in the one occupied by the firewire )if not needed). This card will provide 4 or 5 USB 2.0 adapters. Then buy a USB wireless adapter, which you will be able to use with other computers.
Hope It helps.
Rate this solution if it helps you.
Aug 29, 2009 | HP Pavilion a330n (Refurbished)...
Bcm94306mp ubuntu driver
go to the ubuntu forum they are great people and will get your wireless set up for you.there very good about helping out..i use ubuntu to hack lost passwords and such.
Jun 19, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Toshiba satellite 2805-S301 laptop wireless card
Not wireless ready - as none of the 2805's were ever pre-wired with wireless card antennas. You can install a PCMCIA wireless card, or use a USB wireless adapter. Either one will work - the PCMCIA cards will be faster.
Dec 08, 2008 | Toshiba Satellite 2805-S301 Notebook
Wireless connection
What router brand/model do you have. Is it set up to broadcast it's SSID? Has encryption been enabled on the router?
Have you used Device Manager to make sure the new wireless card is operating properly.
I hope you'll answer these questions and let me try to help before you rate this...
Jan 03, 2008 | Belkin Desktop Card Network Adapter
Toshiba Satellite M35X-S109 Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
