Question about Dryers
I have a Frigidaire Gallery Dryer that has started making a loud shrill noise. It appears that the drum has dropped down. What do I have to replace and how hard is it?
    Problem Solver:
  • 15 Answers
It looks like the bearings on the back of the drum are worn out. You will need to remove the drum to get to it. Removing the drum and remove the bearings, get new one then replace it.
Posted on Sep 10, 2009
Frigidaire gallery dryer making loud thumping noise
IF you have an uneven load this can happen, If the dryer has shifted in position and is no longer LEVEL or the feet have changed their distance leaving a gap or open space. The dryer can also move from vibration and be leaning against a wall or the washer next to it. Check that first, and if none of the above, then the drum may be misaligned. A belt could stretch. The shaft of the drum fits into a connecting part that may be worn and out of round or bearings are worn.
Feb 05, 2018 | Frigidaire Dryers
Frigidaire Gallery Series GLEH1642FS loud noise on final spin
It sounds like something has come loose or some item was placed in the unit accidentally and it got lodged in the drum. You will need to start by taking the front cover off and looking around the drum.
Jan 27, 2013 | Frigidaire Gallery Series GLEH1642FS
I have a Fridgedaire Gallery front loader, was making a loud banging noise on spin cycle, now the whole drum has dropped! help!
The symptoms that you describe sounds like the spider arms that support the drum are broken. It is a very expensive repair. Get a few estimates, before deciding whether it is worth repairing or replacing. Sorry.
Oct 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Spin cycle is making loud clunky noise to a frightening degree. Frigidaire Gallery Washer.
The drum inner bearing which holds the drum unit will be damaged kindly replace the bearing along with the washer to get rid of noise
Dec 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My dryer is making a very loud screetching noise when the dryer is running. it is a full washer and dryer up and down from one another. electric
There are guide wheels and a tensioner in the back that hold the drum steady and the belt tight. The bearings on these can dry out and start to make some very irritaing noises. Pull the unit out and take the back off. Turn the drum slowly by hand and you will probably be able to tell what is makeing the noise. Some light motor oil or sewing machine oil should fix your problem. While your there it would not hurt to get a few drops of oil on all of the rollers and the tensioner pulley.
Nov 16, 2009 | Frigidaire FEX831CS Top Load Stacked...
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Tumbler makes loud thumping noise when in use
no it sounds like your motor may be loose...there should be no gap at all
Jan 20, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Fridgidaire dryer
In dryers, the small clothes can get caught in one of the drum seals and make a scrapping noise, ( remove power, grab a flash light and have a peek inside through the door opening ) or the cloth can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats and so the noise comming.
Nov 03, 2008 | Frigidaire GLER642A Electric Dryer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryers Logo
113 people viewed this question
Top Dryers Experts
