Question about Kenmore 22422 Top Load Washer
OK I HAD A BAD LID SWITCH ON MY KENMORE WASHER SO I BOUGHT ONE THAT LOOKED EXACTLY LIKE MINE. WHEN I GOT HOMWE I FOUND OUT THE PLUG IN WAS DIFFERENT. IT HAS THE SAME THREE WIRES ALL MATCHING COLORS. SINCE I CAN'T RETURN THE SWITCH BECAUSE I OPENED IT, CAN I JUST CUT THE PLUGS OFF AND WIRE IT DIRECT? AS I SAID ALL THREE WIRES MATCH. THANKS
  • roberta3fan May 11, 2010
    How many wires is on the switch you have on the washer?
  • 396 Answers
Look at both switches for markings by the contacts or wires or on the switch itself.
NC = Normally Closed connection
NO = Normally Open connection
C = Common connection
If the colors match the markings on the switch you should be good. If they do not match wire colors, match the markings NC – NO – C marked on the switch. Also make sure the voltage and current ratings are the same or higher than the original switch.
Posted on Sep 10, 2009
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Wash machine will not spin The lid switch is broken and I can't find a part number for it
Their are 3 common lid switches for that style of washer, 2 look very similar and only the end of the plug is different here is what they look loike along with the part number for each
note how the plugs in the first picture is all that is different...the part numbers for all 3 are listed right on the picture.oldtech2332_135.jpg
I hope i have helped ya to determine which lid switch ya need,
GENE
Oct 11, 2011 | Kenmore 22422 Top Load Washer
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
How do i remove my old lid switch and put in a new one
this video will show ya exactly how to replace the lid switch.The number ya have though isnt the model number i can be found under the lid toward the back just above where the water enters the tub order the exact part# by going to searspartsdirect.com to find the part# then you could either order it directly from sears ora local parts dist. that could be found by a quick look in your local phone book or a google seach for parts dist. in your area watch this video.......http://www.youtube.com/embed/MFsvLiuTniU" frameborder="0" allowfullscreen>
Jul 13, 2011 | Kenmore 24032\24036 Top Load Washer
The agitator won't work, and the button under the lid fell off. What can we do to fix it, or would it cost too much to fix it?
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
IF THIS IS A BASIC KENMORE / SEARS TOP LOAD, DIRECT DRIVE WASHER THE PROBLEM IS LIKELY A LID SWITCH. (EASY AND INEXPENSIVE TO FIX)
I'D NEED TO KNOW THE BRAND AND MODEL NUMBER TO BETTER SUGGEST A SOLUTION.
Aug 13, 2010 | Washing Machines
Fills, Washes but won't drain or spin and the timer stops moving at that part of the cycle.  It does this on ALL wash/rinse cycles.
Mine had the exact same problem! After looking around here, I determined it was the lid switch. When you open/close the lid, it should activate a little switch to let the machine know the lid is closed. It should make a distinctive CLICK sound, even when the machine is unplugged. If it doesn't that means the machine thinks the lid is still open and won't go any further as a safety precaution. On mine, I followed directions on this site to bypass the lid switch until I got a replacement part. It is now working fine.
However, after I disconnected it, I realized that I could have fixed the switch itself without having to get a new one. The glue holding the whole switch together was simply not working any more. If I held the switch together, it clicked again. I could have fixed the whole thing with a strong rubber band and saved my self the $35 part and hassle of having to go back and replace it. Oh well, too late now since I already disconnected it from the wires.
Look for Replacing a Lid Switch for great directions on this fix. If the lid switch isn't the problem, by the way, the other solutions seem to be with the pump being clogged. But the way you described the problem sounds like exactly happened to mine. Good luck!
Jul 21, 2009 | Kenmore 23822 Top Load Washer
Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore SM9711031
ok sounds like you have a bad pump or lid switch. ok i want you open and shut the lid really quick...do you hear a click click. if so your lid switch is good and you have a bad pump. write back when you do this. kelly
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer model #11092587210
Almost sounds like a timer or timer motor problem.  Could also be a loose wiring harness around the timer.  When you said it when into spin, but the next day, did the timer move at all during the "break".  Usually, a lid switch will give off that "tell-tale" clicking sound when lifting the lid.  See if it makes this noise, but it really doesnt sound like a lid switch issue.  Really sounds like a dead spot, or spots, in the timer.  Let me know.  Jim
Oct 05, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 22422 Top Load Washer Logo
112 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
