Question about EliteGroup P4M900T-M (V1.0) Motherboard
Mic output sucks!!
I bought the P4M900T-M a week ago, i installed the HD audio driver and i mostly use my computer to record.I had an old intel PC that hat great audio quality from the onboard sound card. When i first tried to record the mic output was very low and now after trying everything its still very low. What must i do?? Is ie the soundcard or the mic??
  • 238 Answers
Re: Mic output sucks!!
Hi, was the mic ok with ur older sound card, if yes then u need a mic with lesser impedance, have u adjusted the sound card recording properties??
let me know..
Posted on Dec 15, 2007
0 characters
3 Points
Tells me mic & line out not plugged in.
Go here and get the Sound driver VIA HD Audio Driver and if you didn't already install it get the Chipset driver too. Install the chipset driver first if you need it.
May 22, 2012 | EliteGroup ECS G31T-M Motherboard - Quad...
How can i install p4m900t-m2, intel pentium ll processor. i dont have sounds.. and audio
When your computer have no sound be sure that the motherboard driver are installed. You need to check this "right click mt computer/Properties/Hardware/Device Manger check if there is a yellow question mark there. If you can see a yellow question mark it means ths driver is not installed that's why your hardware is not working.
To install load your CD driver to your CD room and install.
Aug 15, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
I bought a new Intel Board DG31 PR and i have a problem in audio
Check that mic is not kept on Mute. Usually after installing drivers, mic option is kept mute in most cases. (
Jul 23, 2009 | Intel DG31PR Motherboard
No audio
No. But you, however, can download it online. Just go to your motherboards manufacturers website, look up *********** board model, and download the newest drivers.
Mar 05, 2009 | EliteGroup ECS P4M900T-M2 Socket 775...
ECS P4M900T-M2 Motherboard windows xp service pack 3 audio driver
are you all running vista or xp ? if xp this sound chip will only work with sp1 installed as it is designed for vista
Nov 07, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
For the HD Audio drive to work properly, you also have to install the Microsoft Device driver for HD Audio. You can download both at the ECS download page here:
or here:
Feb 11, 2008 | EliteGroup P4M900T-M (V1.0) Motherboard
Audio not working on new custom PC
in the control panel check sound and audio devices option- audio-default playback device- default recording device. Check whether sigma tel audio is present by default. if not then try changing to dafault audio devices both play back and recording options.Restart computer to check sound is heard this time.. all the best !
Dec 20, 2007 | Intel Motherboard
MicroPhone Not working
Download the latest audio driver from intel site. Install it, ur mic will start working.....
Folloe the link and select Sigmatel audio driver*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21#DRV
Nov 19, 2007 | Intel DG965RY Motherboard
ASUS P5B-MX MoBo Very low sound output.
inthe realteck sound system there u need to adjust the settings in the software set the settings to 2 channel
Oct 24, 2007 | Gigabyte GA-945GM-S2 Motherboard
EliteGroup P4M900T-M (V1.0) Motherboard Logo
89 people viewed this question
Top EliteGroup Motherboards Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Michael Thomas
Michael Thomas
Are you an EliteGroup Motherboard Expert? Answer questions, earn points and help others
