Question about KitchenAid Dishwashers
The door on the dishwasher squeaks terribly. How can this be corrected?
    President:
  • 1,382 Answers
If your dishwasher door squeaks you have to check the following:
Latch
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs
Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges
The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal
If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Posted on Sep 10, 2009
How to fix a squeaky door on a frigidaire gallery dishwasher
Thank you for your post, friend!
I see that you need assistance in repairing a squeaky door on your Frigidaire dishwasher. The best way to quiet down a squeaky door is to pinpoint the cause of the squeak. This could be an issue with your hinges, springs, or the cables. You can use a lubricant such as WD-40 on your those parts to see if that will help alleviate the squeaking. Hope this is helpful. -Matt
Feb 27, 2015 | Dishwashers
Back door makes terrible squeaking noise when
When you open your door you will see a flat bar that slides into the door while opening and closing. It is located between the two door hinges. There is a rubber on the door where the flat bar slides in and out, remove that rubber and you will see little rollers in the door, those rollers need to be oiled, preferably with engine oil. Oil the rollers and work the doors back and forth, the noise should abate.
Feb 21, 2010 | 2005 GMC Envoy
Door is squeaking terribly upon opening and closng - how and where do I oil it?
the door cables and roller guides need replaced. they were redesigned to reduce this problem. not very easy to change. part #8194001
Jan 06, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
How to get to the door cable and pulley that
You need to pull out the dishwasher from under the counter and it runs along the bottom on each side.
Jun 30, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Under counter dishwasher door "squeaks".
The door hinges will have to be replaced. They have been updated to prevent this. Read about it here and good luck.
btw I have used Vaseline applied to the cables to eliminate this issue.
http://www.servicematters.com/docs/doc_main.htm
http://tclaundryrepair.com/
Feb 25, 2009 | Kenmore 46462 Front Load Washer
Squeeking, swaking door springs
Hi there
Thats a common problem with sprung door hinges, get some WD-40 lubricant spray and spray the spring until the squeaking stops.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | KitchenAid Dishwashers
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
551 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
