Question about Westinghouse Refrigerators
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
    President:
  • 1,653 Answers
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Posted on Sep 10, 2009
Testimonial: "thanx so much will try that "
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Fridge is not working model BJ505 upside down fridge freezer and fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Westinghouse Refrigerators
I have got westinghouse fridge. The freezer is working but the fridge does not get cold at all
Is there any sign at all of snow/ice build-up in the freezer section ??
Is the fan in the freezer running ??
Need more info..
Dec 24, 2010 | Westinghouse Refrigerators
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
Mini Danby Fridge Won't cool but compresser is running very HOT!(Model DCR412BLS) the fridge has just recently been moved into a warmer environment without air conditioning. As well, it had accumulated...
never turn a fridge up side down and when moving a fridge or freezer keep it upright as much as poss and dont plug back in for 24hrs.now leave it unplugged a buy new one...
Sep 14, 2009 | Danby DCR412 Compact Refrigerator
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refridgration is not cooling
hi
same thing happened to me with a westinghouse upside down fridge freezer yesterday. i talked to a mate of mine who is a refrigeration mechanic and he said to check the air flow going into the fridge via the freezer and to see if the fan above the evaporator was working. he also said you would probably have to have the fridge light switch depressed as the fan is designed to only run when the fridge door is closed. when i removed the cover in the back of the freezer to inspect the fan i found the fan was spinning okay, but my evaporator was choked up with ice. i gave it a good defrost and clean out and everything seems okay now. i think the heating element around the evaporator (frost free) is not working and that is why it has iced up. apparently it is very important to have good airflow in and around the evaporator so if it is iced up or you have too much stuff in your freezer it will not be efficient and your refrigerator performance will suffer.
to have a rough idea on whether you have enough gas in your system, he suggested feeling the pipes coming out of the compressor. in normal conditions one should be quite hot to touch and the other should be a little bit cooler than room temperature. your condensor (which is the big coil up the back of the fridge should be warm and your evaporator (coil behind a cover in your freezer should be cold to touch)
hope this helped
john
Jul 16, 2008 | Refrigerators
Fridge - Westinghouse siloueete frost free 415 problem
Temperature sensing thermostat could be going bad. Also check to make sure the refrigerator light is shutting off when you close the door. There should be a switch to control the light operation when the door is opened and closed. Operate the switch by pushing it in as if the door was closed and make sure the light goes off each time.
May 18, 2008 | Refrigerators
Refrigerators Logo
142 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
