Question about Mitsubishi WS-55859 55" Rear Projection Television
I HAVE A WS55859 , TOOK IT TO A TECH AND HAD 7 CAPS REPLACED BECAUSE OF BLINKING LIGHT AFTER POWER OUTAGE NOW AFTER 150.00 SPENT THE TV IS NOT BLINKING ANYMORE ONCE I TURN THE SET ON IT WONT STAY ON IT TURNS ITSELF OFF IN SECONDS. CAN YOU HELP??/
  • mslongrun26 Nov 03, 2009
    Coaxial from the antenna to Ant-DTV connection great picture no sound. TV sound set to on. have a solution?
  • 60 Answers
Did the set work after the tech replaced the caps?
Is the work under warranty?
Bad convergence amps would be the first suspect.
Press and hold the menu and device buttons at the same time on the set (not the remote). The led should blink an error code. If it blinks 2 times then 3 times, it is probably the convergence amps.
Posted on Sep 11, 2009
Testimonial: "the device/menu solution worked it gave me: blink-blink blink, blink-blink blink,blink- blink blink, blink- blink blink. repair man will creditmybill"
The green timer light is blinking with no interruption on my WS-55859. TV will not power on after the reset button is reset or is disconnected from power.
Thats almost always caused by failed DM capacitors on the DM power board. There are 7 that will need replacement. There is a repair kit called the WS55859 DM repair kit which has the caps and the CD with repair instructions available from www.tvrepairworld.com
Jul 07, 2011 | Mitsubishi Televison & Video
Power went out last night and now the tv time button is blinking and tv wont turn on
thats caused by failed caps on the DM power board. When the power is lost the caps discharge and then cany recharge when the power is restored. The WS55859 dm repair kit from www.tvrepairworld.com is the correct kit for that symptom the kit contains the caps and the CD with instructions for the repair.
Jun 01, 2011 | Mitsubishi WS-65869 65" Rear Projection...
After a power outage the timer light on the front of the tv panel blinks but the tv will not go on. the owners guide states"If green light on frnt panel is plinking, please wait for at about one...
very common problem caused by failed DM capacitors. You can get the WS55859 DM repair kit from www.tvrepairworld.com which should solve the issue. The kit contains the upgraded caps and the CD with repair instructions.
Feb 16, 2011 | Mitsubishi WS-55859 55" Rear Projection...
We recently experienced a power outage, but once the power came back on, my TV would not turn back on other then a the timer green light was blinking. I pushed the reset button and also unplugged the power...
The blinking green light is the DM unit in the set booting up like a computer.
Several things can happen here--Research by model number with GOOGLE, model number and problems.
It is often called the blinking green light of death.
The most common problem is 4 filter caps in power supply (they run 7/24 and supply voltage to DM unit fail--also some fuses there.
If you look on the net you will find places that sell kit for this repair.
This is also one of a group of several Mitsubishi sets with this kind of problem--It is not the Lamp!
Some of these models develop so many problems Mitsubishi now sells a chassis replacement--includes power and several boards that develop bad caps.
Understand: Mitsubishi has a long history of caps failing in their sets, it goes back almost 30 years. I have seen older ones where over 20 filter caps were bad.
You can talk to Mitsubishi to see if chassis replacement is available for your set--this came about as a result of the threat of hundreds of people entering a class action lawsuit (several).
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a "comment" here and I will assist you.
SD TECH
Aug 24, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Green light flashing in the front ?
SLinteriors posted this on another page and saved me big bucks.
Here's a bit more detail:
The flashing green timer light after a lightning storm seems to be a very common problem with old Mistubishi rear projection TV's. A friend and I had the exact same problem.
Using this and other sites, I spent $36 bucks and a little time with a soldering iron to replace the capacitors on the DM board and got mine up and running (WS55859). I've never really worked on electronic circuit boards before, but the helpful advice at these sites got me up and running. Definitely check it out before you hire someone or replace your TV:
Repair Kit with instructional CD available at:
http://www.tvrepairworld.com/mitsubishi_repair_kits
for under $40 plus shipping.
Discussion of process in detail at:
http://www.hometheaterspot.com/showtopic.php?tid/137881/
for the WS55859 model, which may be a little different.
Jul 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I have a WS 55859 and after power outage i got the green POWER light blinking. I replaced all seven capacitors 1000uf but i still can't switch it in? Any other advice? Rgds FM
If replacing the 7 caps doesn't work I then try to re-solder the small 8 pin ICs. Be very careful and try to avoid cooking it or leaving a solder bridge. If that doesn't work either you'll have to replace the DM-POWER board. You'll beed a Mits authorized service center to order the part. Goodluck.
Jul 05, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Green blinking light following a power outage
I rebuild the DM power supply in these sets with about a 50% success rate. Sometimes changing the 7 1000uf caps on the small power supply in the DM will fix it, you'll also have to solder the small 8 pin ICs as well. Do this carefully as you do not want an accidental bridge. If this does not fix your problem, replace the DM-POWER board not the DM Assembly. It's about a 300 dollar difference. You'll need a mitsubishi authorized service center to order the part for you. Goodluck.
Jul 05, 2010 | Mitsubishi WS-65869 65" Rear Projection...
GREEN BLINKING LIGHT OF DEATH..........
You cannot tell what capacitors are bad just by looking at them. Some can fail without any outward signs. You need a special meter to test them.
Mar 17, 2017 | Mitsubishi WD-62525 62" Rear Projection...
7 red blinks
Is the light blinking 7 times on front of TV ? If u take the back cover of the TV off you should see two leds on the bottom right of power supply turn on when u push the power button. When the TV go into error protection on the upper left of power supply you should see. A blinking green light. Please inform me of the error it flashes and ill will be able to help further. ( Serveral possiblilties it could be from audio, bad power,and faulty Y-main.)
Apr 28, 2008 | Philips 42PF9630A 42 in. Plasma Television
Mitsubishi WS-55859 55" Rear Projection Television Logo
198 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
