Question about Apple PowerBook G4 Mac Notebook
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
I recently purchased a Sharp Aquos LC-20D10-W in Japan and I having problems connection both my older Powerbook G4 (15 inch titanium) and my new Macbook (13 inch white).
I can connect my powerbook via s video without issues. When Itried to connect via the DVI - to the PC port in the back of the TV using an adapetr, my computer recognizes the tv, but I don't get a picture. I then tried with an HDMI adapter and got the same result. I tried switching resolution settings and that also did not work.
I Also tried connecting my macook using the mini dvi port with an adapter with the same result.
Any suggestions would be appreciated.
    Novelist:
    Champion:
  • 382 Answers
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISConnecting Powerbook G4 to Sharp Aquos LC-20D10-W - 0ceaf58.pngct that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Posted on Dec 16, 2007
IPod player won't show on screen of my Sharp LCD LC-46D62U
Hello !
Guess the the cables are not proper connected or cables might have some problem ... or the ipod is not supporting to ur TV output ... first u try out with other Tv and confirm ...
Dec 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-32D40U purchased 8/2006 has sound but no picture most of the time. Cable people certified the cable service as satisfactory. Can it be repaired?
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced. Hoping that this will help to solve the problem....
Aug 08, 2011 | Sharp Aquos LC-32D40U Television
I have the same problem. I recently purchased a Sharp LC-52D78UN TV and I am receiving nothing but Black & White pictures when connected to Direct TV cable receiver. Why and how can it be fixed. I...
I suggest you check the cable input system. It is possible that the cable unit produces S Video or B-G and the TV is set up to receive standard quality RGB.
Hope this helps
Nov 21, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Green screen with software update
phoned sharp who told me the main circuit board had gone. so new tv required.!!!!
May 28, 2009 | Sharp Televison & Video
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lc-19ad22u
where do you live?
is it connected to to RF or AV
Mar 12, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Apple PowerBook G4 Mac Notebook Logo
345 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
