Question about Refrigerators
My sub-zero 532 makes ice that melts and refreezes
I also find that there's often a pool of water in front of the refrigerator side. I have the freezer setting at 8 to try and make it colder, but had the problem with lower settings as well.
Hopefully, you've solved your problem by now, over a year later. If not, a similar problem I have with my 532 is due to the aluminum tube that the water flows through to fill the icemaker. Over time, this metal tube moves away from the icemaker toward the hose it is attached to due to the hose being warmer than the freezer compartment. This creates a gap between the metal tube and the icemaker causing water to spill into the ice bucket each time the icemaker refills. It makes you think the ice is melting and refreezing, but it is really just the water freezing when it spills into the ice. To correct the problem. you have to remove the icemaker, which is not that difficult, if you have a long stem phillips screwdriver. Then grab the metal water tube with some needle nose pliers, and pull it toward you to return it to its original position. If you pull too hard and it comes completely off the hose it is attached to, it is difficult to re-connect, but can be done, as I have had this happen several times, and have succeeded to re-connect it each time with some patience. The metal tube must fit snuggly into the icemaker when the icemaker is re-installed to prevent it from leaking water into the ice bucket each time it refills. My model 532 is now 23 years old and still working. Good luck!
Posted on Dec 08, 2010
  • Peter Filardo
    Peter Filardo Oct 06, 2015
    I'm having this exact issue. I can see the metal tube leading into the icemaker assembly, but its short by like at LEAST an inch. Plus, its way too stuck in place to pull out, closer to the icemaker.
    Ideas?
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Subzero freezer with ice maker. Ice melts and refreezes, into blocks of ice. What could be causing this?
Good day,
In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly.
The valve will many times dribble water into the well after shut off, causing an overflow problem.
The fix is a new water valve kit.
The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
Mar 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
532 ice maker works, but dumps water into ice container with ice.
Do you still have a manual or can tell me the watts power consumption of the 532?
I'll look into your question. Sounds like a sticking icemaker water valve, but I'll have a look.
Mar 03, 2009 | Sub-Zero 632 / S
No water for my sub zero ice maker system 532
Check in two places either behind the fridge or under the cabnit where the water supply is. If not there then check up underneath th back of the fridge
Feb 14, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Sub zero 532: noise increasing.
We have the same SubZero unit and the water leak is the ice maker line or the pan that catches condensation. If you unscrew the panel at the bottom, you will be able to take the pan out and see if the water is from there. If it is from the ice maker line (which was plastic on ours), you should fix this right away as we didn't and we ended up having a $10,000 flood that ruined our hardwood floors. Also, the increased motor noise happened to us as well, but when we had the motor replaced, it is not much quieter.
Nov 15, 2008 | Sub-Zero 632 / S
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
