Problem installing USB to serial port connector/brifge
I installed theusb to serial port connecteor 1 month ago. When I tried using it later it wont work. I reinstalled with the same driver and now it says problem with installation section INF.
    Guru:
  • 402 Answers
When an USB drive makes problem on one computer only then an updated mainboard/chipset driver may help.
If it doesn't help then it may be just incompatible with the computer's USB ports - that's not unusual. Therefore it's helpful to have an additional USB PCI card as alternative in the computer, best with NEC chip.
Cheap USB extension cables may cause problems too. The thinner and longer the higher the risk for problems. The plugs wear out in time.
USB ports on front of the computer are more problematic because the USB is leaded by a cable thru the computer case which is full of interferences. Furthermore the port a mechanically stressed, so the usually fail sooner or later.
Other attached USB devices may interfere, usually such ones that don't use a default Windows driver and which permanently transfer data, such as web cams.
Cheap USB hubs die slowly. First symptoms are disappearing devices and communication freezes.
If an USB device has been detected as 'unknown device' once it might be necessary to delete it in the device manager and replug it then.
Another try is a complete USB device clearing by Microsoft DEVCON and the RenewUSB.bat from http://www.robvanderwoude.com/devcon.html
A cleanup can be done manually too. Put the following two lines into Notepad and save them as DevManager.CMD:
set DEVMGR_SHOW_NONPRESENT_DEVICES=1
devmgmt.msc
Started thru this DevManager.CMD the Windows device manager shows non present devices too if you check "View" -> "Show hidden devices". Under "Disk drives", devices shown with a light gray icon are non present. Just delete them. Same procedure under "Storage volumes". There may be a lot of them...
My commandline tool DriveCleanup does it for all currently non present storage volumes and USB drives.
Microsoft has set up a page for General USB troubleshooting in Windows XP
To have DEVMGR_SHOW_NONPRESENT_DEVICES=1 set permanently, download and doubleclick this file: DevMgr_Show_1.reg. After next logon it takes effect.
It also sets DEVMGR_SHOW_DETAILS=1 to get the "Details" tab in the device's properies dialog under XP.
Thanks For Using Fixya
Posted on Sep 14, 2009
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
How do I install 5 Port USB 2.0 Desktop PC PCI
please re post with the manufacturers name of the card. or go to the maufactueres site and download the drivers for it there. foe example if it is a belkin go to:
www.belkin.com
then go to support and then downloads. they will have it.
Jun 25, 2010 | Computers & Internet
Ipod wont work
If it is under warranty still retrieve the serial number from the back of the iPod and call Apple to setup an appointment at your nearest Apple store to save you time. They only take appointments now that I know of.
If by resetting you mean by:
Holding down menu & play/pause?
If that doesn't work plug it into the computer, make sure you have iTunes installed and then try restoring it. And if THAT doesn't work, make sure you have the lastest iTunes, and firmware. Sometimes computers are a little iffy, if the connection noise is present and disconnected it could be the USB port. Sometimes on my phone/mp3 players it'll do that and they only liked to be plugged back into the same original port the USB driver was installed on. So if you plugged it through the front when it was working try that.
Jun 08, 2010 | Apple Audio Players & Recorders
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Hi i bought a Z4mplus.. I have a laptop that only has usb ports and have connected the zebra with a usb - serial converter... however the computer installs the printer driver but wont send any information...
Make sure the serial port parameters match between the printer and the usb-serial driver. The Zebra printer is usually set to 9600 baud, 7 data bits, Even parity and 1 stop bit. The serial driver is probably different. The mismatch will prevent communications.
Hope that helps !
May 06, 2010 | Zebra Z4Mplus Label Printer
I have lx 800 printer. it is connected to window vista through partallel port adopter with usb connector. please install the driver
what??? first of all Windows Vista does not Support Parallel ports.. second.. visit the printer Manufacture web site.. I guarantee the drivers are located there..
Oct 09, 2009 | Primera Technology LX 800 InkJet Label...
My USB ports don't work
good day,,
your usb port has the problem.. try to follow this steps:
1. Try to check if the usb bus is installed, to do this right click on my computer
2. Click manage
3. Click Device manager
4. On the right side click on the plus sign of the universal serial bus controller
5. Check if all the item is in correct
if you are done and then the problem is still the same,try this one
1. Re-install your motherboard chipset
2. Ensure to install and try to look if the computer install the usb serial bus controller
tanx..
Jan 31, 2009 | Computers & Internet
Computer recognises printer but print requests not actioned
that happened to me with my cannon ip4300 so I installed the driver again so I had 2 drivers installed on the computer. The computer named the seconed instalation cannon (2) .
number 2 worked the first didnt.
so used number 2.
later deleted number 1 .still all ok
wierd but worked.
david267
Jan 27, 2008 | HP LaserJet 4L Printer
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
