Question about Woods 4.3 cu. ft. / 122 liter Chest Freezer C04NAS
If the freon leaks from my freezer will it freezes
  • 396 Answers
No, if it has a leak moisture will enter the system causing an acid build up. Have a qualified repair person repair the leak, replace the freon and pull a vacuum.
Posted on Sep 10, 2009
  • 3,600 Answers
If it leaks it won't freeze anything for long it will soon turn hot.
My ge freezer wont freeze
Did you lay it down when you moved?, if so you may have oil in the lines . Did you bump any Freon lines and cause a leak?
Aug 31, 2014 | Freezers
I have a Magic chef upright freezer i can hear the compresser running but it will not freeze meat
Has this happened suddenly? Look at the shelves to see if there is a frost line. If the shelves that also carry the Freon appear to have a frost line your freezer may have a Freon leak. If there is a Freon leak it will be better to begin looking for a replacement freezer. Let me know what you see, Thanks Sea Breeze
Nov 29, 2012 | Magic Chef 11.8 cu. ft. / 334 liter...
Can you recharge the freeon in a frigidaire upright freezer?It's not as cold as it should be!
I the freon has leaked out, this means there is a leak in your sealed system. Unless you can find the freon leak, charging the system will do no good. It will leak out again. There are many things to cause a freezer to not freeze. Is this a "Frostless" Freezer or a "Manual Defrost"?
Mar 30, 2012 | Freezers
Bottom 2 shelves not freezing
if it does not freeze it is because the refrigeration system is low on freon. this will cause the bottom shelfs to not freeze...
you have to decide if it is worth putting the freon back in (they wont fix it because very hard to find)
so you could spend anywhere from $80 to $150 to get the freon back in... then after a while it will leaks out and you will have the same problem
why dont you instead move that money to a new freezer
hope this was helpful
Mar 04, 2010 | Freezers
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Nov 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
GE upright freezer
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Not freezing
Freon leak. Needs charged. You can't do this yourself as you have to be certified to buy freon.
Apr 09, 2008 | Hussmann Commercial Freezer DCSG-16-D
Woods 4.3 cu. ft. / 122 liter Chest Freezer C04NAS Logo
339 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
