Question about Philips Magic3Voice PPF585 Printer
Replacement roll??? where can you buy the replacement roll on line from? is it easy to replace?
Is there any tricks to installing throttle position sensor in 92 geo storm? Not adjusting. Simply take out two screws and replace part and reinstall screws is it that easy?
Yes its that easy, just make sure you engage the notch on it to the throttle body shaft. You may have to roll it past the screw holes to engage the notch. Then holding it in place on the throttle body, just roll it back to where the holes line up for the screws. Do not over tighten the screws
Jun 14, 2017 | 1992 Geo Storm
Why does my brush turn?
Most likely the belt that connects the motor to the brush has broken and needs to be replaced. A relatively easy fix.
Nov 12, 2014 | Shark 12-Volt Cordless Hand Vac
Brake line replacement/bleeding info
this might be more than you want to takle you can usually buy short lengths from part stores but if you need the full lengths you will need to buy it by the 25 foot roll you will need to double flange each side the parts store you are buying it from should asist I use oreillys then bleeding you must go furthest to the next furthest then down from that
Jan 15, 2014 | 1988 Chevrolet G20
Replace brake line
Brakelines can be challenging to replace or quite easy. It just depends on which one you are asking about. Some of the brakelines are segmented and the ends have short runs. Others are trunk lines which run the distance from the back wheels to the front ABS unit.
The lines will need to be bleed after the changeover.
With the cheapening of the aftermarket parts system, your ability to find a pre-shaped replacement line is more difficult to do.
There are kits which include ALL pre-shaped lines. They can be normal steel or stainless. Looking at the age of your car its hard for an outsider to say how much you need to spend to repair this. The logic is that all lines were installed at the same time and if one fails to others are not too far behind. If this is a car you wish to keep for the Future, replacing all lines is a good idea.
But for a budget, with close inspection of the remaining lines, you can just replace the broken line.
As I said earlier, pre-shaped lines are harder to find. Some people buy a roll of tubing and make their own lines. This is not for the novice.
Hope this helps.
Oct 20, 2013 | 1996 Mercury Cougar XR7
I need to replace the brake line from rear to front on a 2002 Chevy S10, it appears to be stainless steel. Do you have a schematic and does it require special tools
you need to buy a double flare tool(about $20-$25) for metal tubing, a tube cutter, a small tube bending tool, and you can buy rolls that are 25 feet in length-I have learned from experience to use the original fittings as the ones I have bought tend to leak (aggraviting when you get it all together and find it leaks)...Replacing a line is not necessarily hard to do as much as it is time consuming and kind of dirty-you need to pull your old leaking line, find where it is threaded into the master cylinder and the junction block, unscrew the fittings, then remove the tubes-they are usually clipped along the subframe. Save the damaged hose to take to the parts store to get a roll of tubing. You can also use it as a template to make you new hose, using your tuber cutter ($6) and bender (maybe $7)-the tube itself is about $20 for a 25 foot roll and you are going to use your old fittings (free)-like I said, not too bad just have to take your time.
Jul 04, 2011 | 2002 Chevrolet S-10
Passenger side window wont roll all the way up.
I don't know how old the car is, but my windows are always the first things to go.
If the window sounds like its trying to roll up but is getting jammed (while it is rolling up try gently pulling up on the window when it gets to the point where it stops) then it might have jumped off the track.
If pulling up on the window gently while rolling it up allows it to continue and roll the rest of the way then you have a bad window motor.
Both are fairly easy to replace and you can probably buy a replacement that bolts into place from your local parts store. Let me know if you need any more help.
Jun 07, 2011 | Chevrolet 1500 Cars & Trucks
When I weht to put car into gear, the metal arm broke off. I need it replaced ASAP
You can pick up from a Ford Dealership, easy to put in just put arm in line up roll pin, tap roll pin in, Done
Feb 08, 2010 | 1998 Lincoln Town Car
1994 Pontiac Bonneville
if a brake line broken that means it rusted out oil leak from it they sell roll of 3/16 steel line you got to make the line or bye premade line with adaptor its not and easy job to do you have to open the bleeder to remove the air in the line hope its a fixya thanks pierre
Jul 31, 2008 | 1994 Pontiac Bonneville
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
for printing of this machine ttr roll is use you check with another quality of that like canofax roll and cheak out for machine printing.
Mar 11, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Printer problem
Your transfer roller needs replacing.
Feb 22, 2008 | Lexmark T630 Laser Printer
Philips Magic3Voice PPF585 Printer Logo
75 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
