Question about E-Machines eMachines Monitor E15T4
Blue light on/off switch to monitor flickers, but will not turn o
Blank screen-black, just flickers every once in a while when the blue light flickers, but nothing happens. I can't see anything. Any ideas?
  • 1,684 Answers
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitorsblue light on/off switch to monitor flickers, but  - 2.gif parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Sep 10, 2009
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
The monitor green light is on and i get a flicker once in a while is this fixableThe screen is black I have tried different cables and different computers . but still get a blank screen ,when it is first...
sounds like the transistors in the invertor section may be your problem, sometimes the pico fues will blow as well, you can check with a multimeter transistor 5707
Dec 31, 2009 | Dell Computers & Internet
PC won't turn on, blue light flickering, green light flickering
check your monitor's connection, its power and VGA connection to cpu, the cpu may be good but you just see black screen bec. your monitor remained off. please bring it to HP service center for more help
Oct 18, 2009 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Blank screen
You said it correct the fluorescent bulbs are going bad, unfourtunately the are part of the screen (panel).
to replace the panel make sure you get the exact part # from the panel inside rear and check prices online and on ebay.
Aug 03, 2009 | Princeton Digital VL2018W Monitor
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
Monitor started to flicker then went blank
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Dec 24, 2007 | Computers & Internet
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
E-Machines eMachines Monitor E15T4 Logo
456 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
