Question about LG 42LC2D 42 in. LCD HDTV
I have 2 year old an110w & after 30 min use it just stop working? Overheating or what? Is there something that I can do?
I could be over heating,check unit is not full of dust and is in a ventilated area. Also check that the speakers are compatiable ie check Ohms is same on amp as the speakers,this info is usually found on stickers on speakers or you may have to take back cover of the speaker and look on the magnet.The amp should have its info on a plate or sticker on the rear of the unit. Hope this helps.
Posted on Sep 10, 2009
Acer Aspire One notebook.when turn on,starts to boot goes windows did not start screen,can choose option and windows starts to load then just shuts off.if you do not choose option shuts off after about 20...
This is generally a hardware issue - if the computer is under warranty get it fixed through Acer. If not you may need professional help. You don't mention how old the laptop is but if it is older than a year or two and you live in a dusty environment it could be overheating. If the fan is not running or always running on super-high then it is probably overheating.
Another thing to try is using a boot CD (any boot CD will work) and see if the computer still shuts down after that 30 seconds. If yes, definitely hardware. If not, possible that it's a windows issue.
Hope that helps!
Dave
Oct 21, 2013 | Acer Aspire One PC Notebook
I Have a 2002 lincoln ls v6 that is overheating i've change valve cover gaskets,water pump,ignition coils,ts tat ,i let it run for about30 min with the heater on it took awhile for the heater to get warm...
you have wasted money on fixing what has not consequence on the oproblem
overheating is from 4 things
1--- no/insufficient water in the cooling system--air lock in system- fill radiator to cap level and bleed air out
2--blocked radiator cores -- have a radiator shop do a flow test
3-- fan not working--no power from relay, ECM. coolant temp sensor , fuses-- have an auto electrician check the circuit
4--- blown head gasket /cracked head-- have a compression test done
Jul 31, 2017 | Cars & Trucks
I have an electric furnace, it worked fine since it was last repaired, had a bad heat sequencer in it.. but now (3weeks later), it is tripping the 30 amp breaker after a few min of operation ????,...
I ran across a similar problem with electric furnaces years ago. One of the heating elements had failed and the coil was actually making contact with the frame in which it was held. This may be the problem but must be checked with the power off as the chassis may be live. Something is definitely amiss if your unit is tripping a 30 amp breaker and probably will show up on a utility bill next month.
Feb 17, 2011 | Heating & Cooling
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Amp turns off after about 20 mins of bluray playback
Your amp is overheating. Provide better ventilation or rig up some fans. Onkyo amplifiers are known for getting hot.
Peace.
Marco
Feb 05, 2009 | Onkyo TX-SR606 Receiver
LG 42LC2D 42 in. LCD HDTV Logo
43 people viewed this question
