Question about Asko Dishwashers
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
MY DISHWASHER DON'T WORK THE FAULT CODE IS F2. WHAT DOES IT MEAN?
  • Anonymous Mar 16, 2014
    Fagor dishwasher with fault code F2
    President:
  • 1,382 Answers
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Posted on Sep 10, 2009
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
My dishwasher is displaying an F2 error code, how do I clear it?
This means the rotor at the base of the drawer is causing some fault. Check the cavity after taking the rotor out and see if there is anything obstructing. Usually a seed or bone fragment. if problem persists you will have to replace the rotor.
see this Youtube video for removing rotor. New rotor is about $90.
Dec 28, 2012 | Fisher and Paykel Dishwashers
My dishwasher is not working and has an error code of F2. How can I fix this problem?
F2 means that your rotor isn't moving properly and will need to be replace or it needs to be removed and check for something blocking it. Below is a link to a video that will show you how to take your dishwasher apart and repair your Fisher and Paykel unit.
Good luck.
May 05, 2011 | Fisher and Paykel Dishwashers
We have the error F2 showing on our dish drawers
normally the F2 showing on both drawers is unusual.
It is a rotor fault. Which means either the rotor that drives the wash arm and also works as a pump is either faulty or there is some rubbish stuck in the rotor cavity.
Lift the fiter plate out and open the rotor ring. Get the rotor out and inspect. If it looks ok or there was no noise when the F2 error showed up then the hall sensor mounted on the underside of the drawer is faulty.
The hall sensor can be hard to replace unless one has good experience in repairing dishwasher.
Nov 27, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Doesn't drain
The motor rotor is not rotating due to some fault or obstruction.
You can take it out and check. Refer to user guide for instructions on how to take the rotor assembly out.
Jul 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Whirlpool dishwasher Model ADP8966, fault code 2?
Hi.
F2 means Touch Panel Failure - Replace the Touch Panel.
Try first tripping the circuit breaker and see if this can clear the error.
Parts must be tested before replacement.
Dec 02, 2009 | Dishwashers
Fault with my dischwasher
F2 indicates the motor is not rotating.The motor may be jammed or defective. Also , the motor rotation sensor may be defective
Jun 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwashers Logo
671 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
