Question about Sony Cyber-Shot DSC-T33 Digital Camera
The display image unseen and the screen is dark
When I turn on the power of m y camera, it was supposed to display image on the screen whatever your lens pointed at. But instead, my camera display nothing and the screen is dark.What is the problem?
  • 5 more comments
  • jayaprakash Dec 11, 2007
    When I turn on the power of m y camera, it was supposed to display image on the screen whatever your lens pointed at. But instead, my camera display nothing. What is the problem?
  • Anonymous Jan 04, 2008
    display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
    It is sony cyber shot DSC- T33 .
  • Anonymous Apr 13, 2008
    When I turn on my camera the display is blank but indicators like battery percentage, memory stick capacity, SAF are present and when I view previous pictures its there. I tried to reset my camera by pressing the reset button but still I get the same result,
  • jodym May 29, 2008
    I am experiencing the same problem. the screen is dark.
  • Anonymous Jun 17, 2008
    only black screen on lcd display even after power is on
  • Anonymous Jul 22, 2008
    mine too
  • padmasurya Sep 04, 2008
    I have the same problem ,please give me a solution.
In fact I have the same problem with my camera and I spoke to Sony customer service and found that these series of cameras have the problem with the sensor kit and it will be replaced by sony at free of cost.
Please visit the below link for more details on the problem.
http://www.imaging-resource.com/badccds.html
Thanks,
Kumar
India
Bangalore
Posted on Aug 17, 2008
My sony DSC t33 is not catching views only black view is appearing. The stored image is displays clearly
what is problem; give me solution.
Posted on Mar 05, 2008
Display shows ,saf, memory card ,charge symbols but not the capturing image on the display screen.After some time the camera is switches off.
Posted on Jan 04, 2008
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
Feb 26, 2013 | Archos 70 Internet Tablet
Canon power shot sd1000 black dot on lens
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Nov 20, 2009 | Canon PowerShot SD1000 Digital Camera
Light appears, but no image
just change the setting to outdoor. if you read your manual it will explain how. pg 27
Mar 08, 2009 | Canon PowerShot A420 Digital Camera
Light displays on screen but no image
Can you see images taken earlier from memory in view mode ?
Can you access the menu and see it displayed on the screen ?
If yes to both, then your CCD sensor most likely is defekt.
No DIY recommended.
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Black screen on LCD and in the eyepiece
Your camera is a reflex camera, it means what the lens you see If the displays are black it means that there's a block inside the lens, probably the inner mirrors are stuck. Try resetting the camera. Save the photos on the memory disk, disconnect whatever can be disconnect, get out the batteries, and let the camera rest for a day or two If the problem haven?t been solved and you don?t have the knowledge how to open the camera take it to fix, hope the insurance is still good. Good luck
Feb 23, 2006 | Nikon Coolpix 5700 Digital Camera
Image on screen is too dark.
Adjust the brightness of the screen using the Camera SETUP menu. See page 3-14 for instructions. In direct sunlight conditions, you may need to shield the LCD display monitor with your hand.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Open Questions:
Sony Cyber-Shot DSC-T33 Digital Camera Logo
354 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
