Question about Maytag Neptune MAH5500B Front Load Washer
No spin error code Lr Drains but will not spin
  • Anonymous Mar 14, 2014
    Got eror code Lr
    Ran diagnostic got error code 06
    what does that mean?
    Scholar:
    New Friend:
  • 36 Answers
Code Lr indicates a fault or failure with the motor. Manual refers user to contact a service rep. First check your warrantee and do a look up on recalls (you can use the Maytag homepage) as some of the earlier versions of this model were recalled and Maytag has agree to some forms of restitution/repair and or replacement assistance.
Posted on Dec 17, 2007
  • 4 Answers
SOURCE: error code Lr
Lr means locked rotor. I work at Whirlpool and trust me it has nothing to do with soap getting into the control panel. Its the motor.
Posted on Nov 21, 2007
Jahn27
  • 1554 Answers
SOURCE: neptune washer mod.#mah5500bww---washes,drains at
The machine control detected that the rotor is "locked". It happens when no tach signal is sent to the machine control from the motor control either due to a faulty motor control board, a faulty drive motor, or a faulty wiring harness connection between the motor control board and the machine control board.
Disconnect power to the washer prior to servicing to avoid the risk electric shock. Open the washer door and turn the drum manually to verify whether the rotor or the tub bearing is stuck or not. Proceed below when the drum rotates freely; otherwise refer to the next troubleshooting guide.
Remove the four screws from the rear of the console attaching it to the rear cover plate. Cushion the top cover of the washer with a cloth. Grasp the top of the console and gently rock it forward away from the rear cover plate, and then flip the console to the top of the washer to access the machine control board.
Disconnect the 4-pin and 3-pin wiring harness connector at the left bottom of the control board including the 3-pin connector on the right bottom side. Clean the connectors and the pin terminals using an old toothbrush or any similar tool and electronic cleaning solution; 70% alcohol will do.
Hold only the edges of the control board when cleaning the terminals to avoid electrostatic discharge (ESD) to the electronic components that may cause damage to the board. Touching the unpainted part of a concrete wall or metal water pipeline repeatedly will help prevent ESD damage.
Reseat the wiring harness connectors repeatedly. In this manner, the terminals are thoroughly cleaned to ensure a good connection.
Reinstall the console by aligning the hooked tabs at the bottom of the console with the slots in the top cover. Insert the tabs into the slots and rock the console back into position then secure it to the rear cover plate with the four screws removed previously.
Posted on Mar 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Maytag washing machine MAH5500BWW gives me an Lr error message
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: Drum doesn't spin error code LR
The LR code means "locked rotor" - the control is not seeing the motor turning.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $^$W#TG
SOURCE: Maytag MAH5500BWW no spin no agitate, fills and
my maytag mt6600tq will not agitate or spin
Posted on Jan 12, 2011
I have a front loading machine(CAH4205AWJ) & it keeps giving me a Lr code.some times it fills with water and drains but never spins.
The LR code means "Locked Rotor". This could be due to:
  1. The control board at the top of the unit has lost connection to the motor and its control board at the bottom. Check for loose connectors. Also try 're-seating' each connector by pulling it off and pushing it on two or three times.
  2. The motor and/or control board at the bottom are shot.
Jun 18, 2014 | Crosley Washing Machines
Error codeLr?
Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. You don't mention in your question if the LR code occurs every load or once a week.
More information on when the error is occurring would be helpful resolving this problem. Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down. This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes. At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Feb 14, 2012 | Maytag Washing Machines
What does error code Lr mean
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning. Usually when the LR code is displayed the motor has stopped turning for some reason. By definition the LR code means the control has tried to turn the motor but was unable to. The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing. The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down. could also possibly be the Water Inlet Valve w/Thermistor #22003834 needs to be replaced due to having Well Water with lots of sand, in the water it is not closing the valve properly allowing water to continue filling the tub, causing it to read the load being too heavy and also leaking out the front door
Nov 27, 2010 | Maytag Neptune Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Does not spin dry. Code LR
LR is a error code for service on the unit. This code is referring to the motor not working properly and needs to be serviced.
please call 1 (800) 344-1274 U.S. to locate the nearest service provider or visit www.maytag.com
Jun 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Feb 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but wont wash or spin
The code LR stands for locked rotor you will need a new motor and motor control kit pretty expensive and only covered under you warrenty for a year!
Aug 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
950 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
