Question about Frigidaire FES367 Electric Kitchen Range
Frigidaire Stove beeping F1,How do repair this?
  • 8,197 Answers
The f1 code means that the EOC (Electronic Oven Control) failed. You need to replace the EOC board.
Good Luck And Please rate
Posted on Sep 10, 2009
5 Suggested Answers
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
  • 39 Answers
SOURCE: F1 fault code Frigidaire electric range
all solutions on the F1 show to replace the EOC control.
Posted on May 22, 2009
SOURCE: Beeping F11 error on Frigidaire
F11 is definitely a key stuck failure and I didn't require any parts to fix this.
The cause of the problem is an over abundant use of double sided tape at the factory. I suspect that either heat or continued use of certain buttons causes the glue to weep into the button/contact pad causing the button to stick to the contact. On powering up our range showed PF and if you waited 10-15 secs without touching any keys F11 would display and and there was continuous beeping. I verified this was the case by removing the upper rear panel of the stove and disconnecting the keypad connector from the upper left of the lockout board. Then on powering up our range simply sat there showing PF. Of course you can't get past this with the keyboard disconnected anyway.
The fix--- to make repair easier I removed the glass panel to which the keypad is stuck from the range. Pull off the burner knobs and you will find plastic nuts holding the glass panel to the metal housing. Remove the plastic nuts (make sure you let the keyboard connector go first by pulling the connector lock -small tabs on either side of the keyboard ribbon - towards you about 1/8". The ribbon cable will then slide right out.) Use a razor blade to gently work your way around the plastic trim bezel and remove the bezel. The keypad actually consists of three plastic sheets sandwiched together. You only need to remove the top 2 layers. Layer 1 is the printed keypad and layer 2 is the contact pad.
You have to be careful in all this or you may crease or damage a panel. I started the edge with a razor blade and then stuck in the edge of a spatula. The idea is not to slide the spatula in but rather to insert it a small amount and lift. Slide it in a little more and lift. Just have a little patience and don't simply try and slide the spatula in or you may scrape the keypad and/or contact pad. While I suppose the more AR of us would then have to clean all the double sided tape off I simply cleaned up the keypads and matching contact pads. I stuck the whole thing back together and reattached the keyboard ribbon cable (hold it in place while pushing in the cable lock mentioned above. If you aren't too squeamish you can test the keypad while you have everything apart as follows: Connect the contact pad (this is the part with the ribbon cable attached) to the lockout board. Power up the stove. At PF touch one of the keypads to the stop/cancel contact pad. The PF should be cleared and you should be able to operate the oven by touching one of the keypads to appropriate contact pads.
Posted on Jan 19, 2010
Our frigidaire stove or the oven is locked and it just keeps making this beep noise and the oven wont unlock so we really need help unlocking the oven and stoping the been noise thanks
The "F1" error code indicates a failure of the Electronic Oven Control or EOC circuit board. You may find the oven gets too hot, fails to respond to input or acts irregularly when the EOC is malfunctioning or broken. While this code usually indicates a need for repairs.
Read more: How to Troubleshoot a Frigidaire Oven F1 Code ' eHow.com http://www.ehow.com/how_10004808_troubleshoot-frigidaire-oven-f1-code.html#ixzz2EhW21T4n
Dec 11, 2012 | Ovens
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F1 and beeping sound on electric stove model FEF365BWF
Hello, the F1 and the beeping sound is as a result of the Electronic oven Control Failure (EOC), and you need to replace the electronic oven control also called the EOC or clock.
Thanks
Jun 13, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F1 CODE ON FRIGIDAIRE STOVE
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Aug 15, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Stove stays on and 30 min. later it starts beeping and F1 code
An F1 error code indicates a faulty keypad and /or ERC electronic control.
Jan 02, 2009 | Frigidaire FEF366 Electric Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire FES367 Electric Kitchen Range Logo
1,829 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
