Question about Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-3160 all in one printer is making a loud clicking sound every time it prints. I htink the print process has slowed down and become unreliable ays this has developed. Any ideas?
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Posted on Feb 07, 2008
  • 18 Answers
SOURCE: Samsung clx-3160 won't print
On the printer. Check under menu > Network> TCP/IP> If it comes up Static then hit the ok button to check the static address it gives you (should be 192.168.1.xxx). Make sure you don't change anything (use the back button to exit). Just copy it down. If it comes up DHCP then it is set up to obtain an address automatically. On your PC in Windows XP, Go to printers/faxes, right click the Samsung CLX3160FN and click on Properties. Click on the Ports tab. Check to see that there is a check mark next to standard TCP/IP it should say Samsung CLX-3160FN next to it (or not) (the name is only used to identify the port from others) and higlight it. Click on Configure Port. IF YOUR PRINTER WAS SET TO STATIC then the TCP/IP address here should match the address you copied from the printer. If your printer is set to DHCP but can't communicate with the PC you may want to set your printer to Static and set the TCP/IP address manually. you have to use 192.168.1 the last three digits should be higher than 100 and lower than 200. I have mine set to 192.168.1.104 and it is working fine. You just have to make sure that the numbers on the printer and the numbers under your port setup in Windows are the same. IMPORTANT: THIS ADDRESS HAS TO REMAIN UNIQUE TO YOUR CLX-3160FN AND MUST NOT BE DUPLICATED IN ANY OTHER DEVICE ON THE NETWORK OR IT WILL CONFLICT. IF THAT HAPPENS RAISE THE LAST THREE DIGITS OF THE ADDRESS TO STAY AWAY FROM ADDRESSES USED BY OTHER DEVICES. I have an HP laserjet and a print server with an Epson Photosmart on it also and I had address conflicts. I set them all on static with a unique address for each and now they don't collide and work fine. If you have to, you can set up a new port for your printer under windows. Same as above just click on add new port and follow the instructions. Again make sure that you use the same port number you have the printer set up under Static. I hope this helps.
Also check on these:
1) try using a different port on your router (sometimes ports go bad) If it is, get a new router.
2) try using a new ethernet cable, make sure it is Cat 6. For some reason these high end MF like that better.
3) Check the lights on the back of the printer next to the ethernet connection. You should have a yellow light and a green light. The green light should be blinking when it is communicating on the network. The yellow light should stay solid to show a connection.
4) Make sure your ethernet card on the PC is activated. Control Panel> Network Connections - depending on your machine there should be a local area connection that shows a couple of monitors with a tee connector and a cable with a lock going from one to the other. If it is dissabled it would have a red X accross the cable. If it does, right click on it and click on enable.
Good Luck
Posted on Aug 18, 2008
SOURCE: MESSAGE REPLACE/ INSTALL TONER WASTE TANK EVEN THOGHT I HAVE REPLACE IT ON A SAMSUNG CLX-3160 FN
When this happened, I took the tank out and shook it out into a garbage can (do this outside and be very careful not to breathe the dust). I then took a shop vac and held the hose at the opening while blowing compressed air into the tank. Wiggle the air nozzle around and you'll get out 99% of the toner. Pay extra attention to the sensor optics (plastic bulges on the sides of the tank).These need to be clean since the printer knows when the tank is full because the toner blocks light shining from one side of the tank to the other
Reinstall the tank and be sure it is fully inserted. If they printer is still on, turn it OFF. Close the front door of the machine and turn it back on.
Continue printing.
Posted on Jun 15, 2009
  • 12 Answers
SOURCE: deve home sensor error on samsung clx-3160
This can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Below steps are for the CLP-300 which has the same Imager/Developer. It's just a bit more involved taking off the top in the CLX-3160.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Posted on Jul 10, 2010
  • 670 Answers
SOURCE: Paper keeps jamming on Samsung CLX-3160 FN. How do
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Posted on Oct 04, 2010
Testimonial: "This solution worked for me. Thanks for the worthwhle advice!!"
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
Samsung clx-3180 printer is showing printer offline and will not print from pc.
CHECK
Printer is connected and power ON
In panel contro
go to Printers
choose Samsung Clx rigth click
unmark the check Use printer offline
Try printing a test page
rigth click Properties
click on
Print test page
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
I have a Samsung CLX 3160 Laser printer that has uneven printing of Black print only. It prints other colors properly, so it is likely the black laser cartridge feeder port that is partially clogged up,...
If your printer prints like this with faded or uneven print,
slamfix_20.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Jan 05, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Fine horizontal dashes in black have begun appearing all over the pages whether I print in b&w or color. This gets worse with each page in a long document. Samsung CLX-3160.
Your problem is the black toner cartridge pickup drum has become scratched and is depositing "extra" black toner onto the paper prior to the fuser roller. you need to replace the drum and all should be ok then
Jul 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
Samsung CLX-3160 I put in a new black toner because the older one
This is the problem in the Black developer in the Imaging unit. Please call samsung or visit authorised service center
Nov 09, 2009 | Samsung CLX-3160 All-In-One Laser Printer
My samsung clx-3160 colour laser printer does not print very well.all prints are barely neglible and now most times no print or characters appear.I have installed new ink cartridges.Please advise.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Jun 29, 2009 | Samsung CLX-3160 All-In-One Laser Printer
1) You need to configure the IP address on the printer to get it printed thru network.
2) Scanner Locked, there's a lock underneath the scanner bed,make sure it's fully released.
Feb 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
66 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
