After reformating windows xp pro my computer reboots and tells me that some windows system is corrupt and tells me to repair when i try to repair it loops back to the same error page i need to know how to reformat again because i can not figure it out
    Genius:
  • 1,250 Answers
Check your RAM
Posted on Sep 10, 2009
  • 19,396 Answers
The Windows system boot file is probably damaged.
The best thing to do is reinstalling the system.
This can be done either using original recovery CD, or using Windows setup disk.
To preserve your data you will need to chose partial recovery or upgrade setup.
Windows CDs has also a tool called Recovery Console that can be used to repair this kind of problems.
Here the procedure to fix the problem using Windows Recovery Console:
  • Insert Windows Setup CD, then start the computer.
  • When Welcome to Setup screen appears, press R.
  • When asked, chose the Windows installation you wish to repair (eg 1) , then press Enter.
  • When prompted, enter the administrator password .
  • When command prompt (DOS screen) starts, enter the following commands./ (if C: is not your Windows system drive, then change the drive letter)
    ATTRIB -H -R -S C:\BOOT.INI
    DEL C:\BOOT.INI
    BOOTCFG /REBUILD FIXBOOT
  • Remove the Windows CD from drive and restart computer.
  • 13,433 Answers
Use the windows installation cd, do a fresh install, format the whole drive in the windows xp setup. - http://support.microsoft.com/kb/316941
see the part about a clean install or fresh install.
I have a computer that runs xp pro. it will not boot and it says it needs system32\DRIVERS\pci.sys file. I can not get my set up to run it says I have error 7. What to do ???
your xp might be corrupted. try to repair your windows xp by inserting your Windows XP CD to the cd rom and run it from CD ROM then "REPAIR".
Sep 10, 2011 | Computers & Internet
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
How to solve pci.sys error during reformating of the hard drive
You have two ways to solve the problem of "Pci.sys Is Missing or Corrupt"
Error Message When You Start Windows.
1.Booting with WinXP CD to access the Recovery Console’s Repair option,
and then copy from WinXP CD the missing or damaged Pci.sys file to
Systemdrive:\Windows\System32\drivers folder , Exit and Reboot.
start the recovery console and type:
set AllowAllPaths = true
expand d:\i386\pci.sy_ c:\windows\system\drivers32 /y
If you don't type
set AllowAllPaths = true you can't access the windows folder.
2. Booting with WinXP CD and then perform a Windows XP Repair Reinstall
of the currently installed system.
If you need detailed assistance post with details of your Operating system
[WinXP Home vs WinXP Pro and the SP status i.e SP1 or SP2 ]
See
http://support.microsoft.com/default.aspx?scid=319136
Jan 12, 2010 | Microsoft Windows XP Home Edition
Xp pro will not load
HELLO THERE:
when you start the computer hit the f-8 key repetedly and the xp pro advanced boot screen should show up now select last known good configuration that worked then hit enter and the computer will reboot and hopefully this will get you going also make sure there is no cd rom in the drive ok? please let me know how this goes there is more we can do if needed please dont forget to rate the solution i have provided this helps me out as well
best regards mike
Aug 06, 2009 | HP Pavilion N5350 Notebook
Thinkpad won't load xp
Try setting up xp again. If you need the files as is, try repair from the xp cd while boot from the cd.
May 27, 2009 | IBM ThinkPad T21 2647 Notebook
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
Mukesh_ibm@yahoo.com
May 12, 2009 | Microsoft Windows XP Professional
XP Repair (non deleting) hangs at 2-minutes / saving settings
you have a very bad virus, try to re-install windows, or go to safe mode if you can open in safe mode and then click start and run and type msconfig and then go to startup tab from up and clear everything and reboot it
Jan 05, 2009 | Computers & Internet
Rebooting when try shutdown
It seems that some minor windows files are corrupted, you needed to insert the Windows XP CD and try to fix the files by re-installing the system... this will restore the corrupted files.
Good luck.
Nov 05, 2008 | Microsoft Windows XP Professional
Windows xp reboot at the start up again and again
plz try to boot in safe mode, if the problem persists than you have to repair or reload the operating sysytem
Jun 24, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
