Question about Microsoft Windows Vista Ultimate Edition
I want restart the Vista Sidebar - Microsoft Windows Vista Ultimate Edition
    Problem Solver:
  • 8 Answers
By restart I am assuming you have just turned it off for some reason. Go to the bottom right of your task bar and find the icon for the taskbar. It looks like a little computer with red and yellow boxes beside it (they're very small).
If you can't see the icon you may have to expand the list of items down there by clicking the little arrow on the far left of the little list of icons.
Once you have found it just right click on it and choose open from the menu.
Posted on Sep 10, 2009
Windows 7 gadgets working wrong
You dont need side bar anymore, rightclick anywhere on desktop and goto gadgets, Add the ones you want, put them where you want (side, top, anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must be aware of the bug that whenever UAC is switched off, Sidebar and Gadgets in Vista fails to display properly on Windows 7 Desktop. Though this is not for every machine but many users have reported this problem that their Sidebar and Gadgets are not working properly.
For older beta versions of Windows 7 there had been some temporary workarounds for the same problem. But if you are using Win7 Build 7000.0.081212 then this can be fixed using a simple registry hack which like in Vista will Elevate your Sidebar and Gadgets Process.
If you know how to play with you registry Editor then just open regedit.exe from Run command in Windows 7 and go to KEY
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
\CurrentVersion\Sidebar\Settings From there edit the DWORD value of AllowElevatedProcess and set it to 1. You don’t need to restart your Windows 7 computer after this. If your sidebar and Gadgets were not working properly earlier then they will be fixed instantly.
Jun 19, 2010 | Microsoft Windows Vista Home Premium with...
Tip
Windows Vista: How to enable or disable the Sidebar
The Windows Sidebar, introduced with Windows Vista, is a way to have one-click access to websites and widgets right from your desktop. Some people love the Sidebar and some people hate it. Whichever camp you happen to fall in, enabling or disabling the Sidebar is a painless process.
To disable the Sidebar:
1. Right click on the Sidebar icon in the notification area (a computer screen with different colored blocks on its right side).
2. Select Exit from the menu.
3. If a confirmation window appears, click Exit Sidebar.
To enable the Sidebar:
1. Click the Vista orb and type "sidebar" into the Search bar.
2. From the search results, select Windows Sidebar. (If Windows Sidebar is the highlighted item, you can just hit Enter.)
3. The Sidebar will appear, in the same place and with the same widgets as the last time you used it.
An alternate way to enable the Sidebar:
1.Click the Vista orb.
2. Select All Programs.
3. Select Accessories.
4. Select Windows Sidebar.
To configure the Sidebar to load automatically every time you start your computer:
1. If it's not already enabled, enable the Sidebar (using either of the methods described above).
2. Right click on the Sidebar icon in the notification area.
3. Select Properties.
4. Put a check mark in the box next to "Start Sidebar when Windows starts."
5. Click either OK or Apply.
If you have the Sidebar set to load automatically and then you disable it, it will still run every time you start your computer, unless you remove the check mark next to that option in the Sidebar properties.
on Jan 09, 2011 | Microsoft Windows Vista Home Premium with...
Tip
How to disable the Sidebar for all users in VISTA.
While the VISTA sidebar can be a helpful tool in the home environment, in the business world it is often viewed as a resource hog which needs to be removed.
In order to keep the sidebar from starting on a computer in VISTA, click on the start menu and open a ren dialog. Type gpedit.msc and hit enter. This will bring up the local GPO snap in. Under the heading Local Computer Policy, expand the section labeled Administrative Templates and then expand Windows Components. In this section you will find a folder named Windows Sidebar. In the Right hand window, double click on the option labeled Turn Off Windows Sidebar and check Enable. Click OK and restart your computer. That's it! Now everyone who logs into that computer will have the sidebar turned off by default.
on Aug 26, 2010 | Computers & Internet
Windows vista sidebar aplication
start it again ... ask windows help for particulars
Oct 31, 2009 | Microsoft Windows Vista Home Premium with...
I turned on my PC one day, and sidebar just decided not to go. I dont know why or how to fix the problem. I went to do a system restore, but noticed i had no system restore points set.....can anybody help...
Having a sidebar problem would indicate you're using Windows Vista, so I'm going to go from there. Microsoft has had a lot of problems with the sidebar feature, and has dropped it in Windows 7. I strongly recommend that you turn it off and leave it off. You can get things you need for your desktop without using the sidebar.
As far as the restore points go, you should have several set up automatically, but since you don't do the following:
Click on the start button, then find "Computer" (or My Computer) in the right column. RIGHT click on Computer, then left click on Properties. This brings up the System window. Select System Protection from the column on the left side of the window (Task List). Click the CREATE button near the bottom of this window to create a restore point.
Give the Restore Point a unique name of your choosing.
Of course this won't help you now, so I would shut off the Sidebar and try to live without it. Otherwise, go to the Control Panel, find the sidebar icon and click it. Set it to open the sidebar when you start Windows. You may need to reset your preferences to get it back to what you wanted.
If this doesn't work, you probably have some type of Malware or virus on your system. The best way to check for this is to go to the following web page: www.malwarebytes.org - and download the program using the blue button. Install it (click RUN) and update it, then let it run a scan (follow the instructions). Once it's done, restart your system and see if it's fixed.
Usually, restoring your system for a sidebar problem really isn't a useful or good way to resolve the issue. For one thing, on some systems, the sidebar seems to randomly decide not to work, and on others it seems to cause other system problems. I've seen very few Vista systems that did not improve with the sidebar feature shut off.
It's important with Vista to be very particular about keeping the Malware off the system, and keeping the registry clean. Using CCleaner.exe is a good way to do this. Clean the registry at least once a week, and do NOT defrag more than two times a year. Vista seems to not appreciate too much defragging. Keeping your system healthy and shutting off the sidebar are two of the best solutions for most Vista problems. Finally, I recommend you upgrade to Windows 7 as soon as possible. Even the RC-1 is better than Vista.
Oct 09, 2009 | Computers & Internet
Windows Vista Pavillion PC Problems with date & time sidebar
The best solution is to re-install vista. But, for the sidebar problem, try searching for "sidebar.exe" in the start menu. When you find it, right click it, click properties, then checkmark "start sidebar when WIndows starts"
Jun 14, 2009 | Microsoft Windows Vista Ultimate Edition
Windows sidebar stopped working
Here is a solution I found when I was having problems and it worked like a gem..its a problem with two programs running a .dll file:
1. Open a command prompt by being Administrator (Right click on Command Prompt and click Run as Administrator)
2. CD to C:\Program Files\Windows Sidebar ( cd drive letter:\Program Files\Windows Sidebar )
3. Run these commands in this order:
1. regsvr32 -u sbdrop.dll
2. regsvr32 -u wlsrvc.dll
3. regsvr32 atl.dll
4. regsvr32 sbdrop.dll
5. regsvr32 wlsrvc.dll
Then start up the sidebar.
Good luck. If you have any questions let me know.
Apr 02, 2009 | Microsoft Windows Vista Ultimate Edition
How to restore windows vista side bar
2 solution for this problem
1) start - all programmes - accessories - windows side bar or
open the Start menu and in the search line type this word: sidebar
and hit Enter key
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
314 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
