Question about Whirlpool Microwave Ovens
I have a Whirlpool model MH6151XHT-1 which has two light bulbs. The cavity light quit working in either high or low. Upon checking the lamps, one was bad. I switched the socket position of the good lamp and I cannot get either high or low level to turn on the lamp. Any thoughts of what is going on? Larry
  • Whirlpool Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Sep 11, 2009
Cannot find the lamp on my h5972 model microwve
Isolate from mains, open oven door, look on left side of cavity you will see a rectangular panel with a screw at the top, remove the screw (torx20) the lamp is a small halogen bulb (like a christmas light). wear a pair of latex type clothes, pull out the old bulb (it looks like a small piece of glass with two small wires poking out). Replacement part is 491743. Probably best to get the new bulb first so you now what you're looking for.
Feb 26, 2013 | Neff Microwave Ovens
Need instructions for replacing light bulb in Sharp Microwave Oven Model R430EK
When you have the new lamp to hand, so you know what you are looking for, remove from the mains supply and remove the case. The lamp is generaly near the vent or transparent poit in the cavity, that used to let the light shine through.
Remove the old lamp and fit the new one, taking care not to leave any wire ends free.
Jan 05, 2011 | Sharp Microwave Ovens
No socket for bulb on left side of oven
The oven cavity lamp is hidden up on top. You have to unplug the oven and remove the single piece top/side cover to get at it. Typically, you have to take out screws on the back of the oven along the top and side edges. Sometimes there are also screws in the sides and rarely along the bottom edge. Once you get these screws out, pull the cover back about 1/2" and lift it away. Look for a standard appliance light bulb right over the holes in the oven cavity ceiling or wall where the light normally shines in.
Dec 30, 2010 | Maytag MMV4203D 1100 Watts Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Change the lightbulb
take the outer case off light will be accessible for you to change it
Dec 08, 2009 | Microwave Ovens
No Cooktop Lamps
9a1ba72.jpg You can solder a wire on here to bridge the broken trace. 1 min fix!
Jan 31, 2009 | Whirlpool MH1140XMS Microwave Oven
Whirlpool Microwave Model# MH1140XMQ-1
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover, what you mentioned as the white cover plate.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can order parts by entering your full model number here.
Nov 23, 2008 | Whirlpool MT8118XE Microwave Oven
Maytag MMV5165AAS work surface light won't work. I bought a new light and replaced the old one but it still will not turn on. THe microwave display goes thought the cycle of High, Low, Off but nothing...
If the lamp socket has power (and it's the right voltage) and the replacement lamp is the correct one and tests good, then the trouble is in the socket. It may have been damaged when the original lamp went "poof." Check for damaged contacts (burnt or broken off). Also, make sure you're seating the lamp correctly in the socket. If the bulb is a push-and-turn ("bayonet") type, you may be facing it the wrong way and it's not going all the way in.
Nov 11, 2008 | Maytag MMV5165 Microwave Oven
MICROWAVE BULB
Hi There!
Most microwave ovens today requires you to remove the cover to replace a lamp. Normally situated next to the Magnetron. Check the inside cavity for tiny holes where the light is suppose to shine through. This will indicate where the lamp is situated. Remember to unplug from mains before opening the unit and try not to touch the High Voltage components. They may still be charged. Good Luck, JUS004
Feb 26, 2008 | Microwave Ovens
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
Microwave Ovens Logo
57 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
