Question about Microsoft Windows XP Professional
How do i get an network administrators passsword
  • hannibal77 May 11, 2010
    Did you set one up when windows was set up? If you did not or do not know then boot Windows into safe mode by pressing F8 during boot process. You should see a list of startup options. Select safe mode and you should get to a logon screen with an administrator logon. With any luck it will be blank and let you in right away. Is this what you mean?
    Brigadier General:
  • 10,406 Answers
Ask the administrator of the network for the password.
Posted on Sep 13, 2009
Ask your network administrator :)
    Brigadier General:
  • 4,090 Answers
Unless you are given the status by a network manager you can't. Admin logins are set up when the network is installed, or by an existing network administrator. Breaking into netwoks is a criminal act unless you have the rights.
We do not provide this type of information without a special clearance from the network owners. Who possible have the password in their safe
Posted on Sep 10, 2009
Name and passsword belkin f7d1301
  1. Choose a laptop or WiFi device that is currently connected to your network. If none of your devices are connected, use an Ethernet cable and connect a computer or laptop directly to your wireless gateway.
  2. Open a web browser and go to the Admin Tool (http://10.0.0.1) - this is the wireless gateway's administration site. The default settings are:
    • Username: admin
    • Password: password (case-sensitive)
    • Note: If you changed your Admin Tool password previously, you will need to use your new login information. If you don't remember your Admin Tool password, you will need to factory reset your wireless gateway. Instructions on how to do this can be found by reviewing the wireless gateway user guides at Wireless Gateway Guides.
  3. On the left navigation menu, select Gateway, then Connection and then Wi-Fi.
  4. Under Private Wi-Fi Network, you'll see the Name (SSID) of your WiFi network. (You may want to write down this information.)
    • Wireless Gateway 1 customers, click EDIT at the right.
    • Wireless Gateway 2 customers, click EDIT for both 2.4 GHz and 5 GHz bands to view the settings for each. ?
  5. Check the box next to Show Network Password. The Network Password (Network Key) will be displayed above. (You may want to write down this information.)
    • On this page, you can also edit your wireless network information, including changing your Network Name (SSID) or Password (Network Key). If you make any changes, remember to click SAVE SETTINGS.
  6. Now that you have your Network Name (SSID) and Password (Network Key), you can connect your WiFi devices to your network.
  7. If you have changed any information, use the new information to reconnect all your WiFi devices to your network.
Learn how an XFINITY Internet subscriber visiting your home can connect to WiFi without sharing your Network Name (SSID) or Password (Network Key)
Jan 04, 2014 | Linksys Wireless-G Broadband Router
I can't remeber my passsword for my e-machine 725
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Oct 03, 2012 | Acer eMachines 520-2890 Notebook
My router is password enable before but no its not,how can i make it passsword enable again?i know my password
Here are some basic steps in setting up your Linksys router
Hope it helps!
Please follow the below instructions to protect your device:
  1. Connect your computer to the router using a network cable, or you can connect to the router through a wireless connection. Note that your wireless card in your computer must be enabled.
  2. Open your Web browser. Enter: http://192.168.1.1 in the address field. This is an internal IP address to access your router. Press the Enter Key.
  3. When the password request appears leave the user name field blank. By default, the password is admin.
  4. After logging in, you are not required to change the default administrative password. However, it's fully recommended that you change the default password by clicking on the Administration tab and Management. Enter a new password in the Password field and again in the Re-enter field to confirm.
  5. I recommend setting the Remote Management item as Disable. It will be another layer of security for your router. With this configuration you can only access your router for programming using a standard Ethernet network cabling.
  6. To save the new password, click Save Settings at the bottom of the page.
  7. To avoid intruders accessing your wireless connection we'll start to work with the Wireless tab.
  8. In the Basic Wireless Settings enter a name for your wireless network connection in the Wireless Network Name (SSID). Set the Wireless Broadcast to Disable.
    When wireless clients survey the local area for wireless networks to associate with, they will detect the SSID broadcast by the Router if the Broadcast is enabled. Do not broadcast the Router SSID. It must be Disabled.
    Note that your SSID should be set following similar rules for setting a password, e.g. at least 8 characters, a combination of letters, numbers and non consecutive characters.
    Disabling the SSID broadcast is not a strong security setting, but it can help prevent intruders from sharing your WLAN. Remember to save your settings.
Jul 15, 2011 | Linksys Wireless-G WRT54G Router
How do I password protect my network using my mac with the rca DCW615R
You can protect you passsword using LoginTrap http://www.protemac.com/LoginTrap/.It’s really good program. Try)
Jun 26, 2010 | RCA DCW615R Wireless/Cable Modem
I forgot my log in password
i have a iso image can send you burn it to cd then reboot then can reset login to log onto windows, need email address to send to
Feb 07, 2010 | Acer Computers & Internet
Changing username/password
Go in as an administrator ... go to control panel ... user accounts ... change name
Oct 31, 2009 | HP Mini 1035NR Notebook
I forget administrator password in winxp
Goto safe mode there you wlll see the administrator account .login with administrator account and then goto control panel and then open 'user' .now select the user for which you want to change the password..
Aug 22, 2008 | Microsoft Windows XP Professional With...
Forgot
welcome to FixYa
well only way i know of other then using a hacking tool is to restore the computer...you can restore the computer with out deleting any of the info should not give you a passsword to log in after that
hope this helps out have a good day :)
Jul 16, 2008 | Fujitsu LifeBook A1010 Notebook
I put a password on my computer & then made a Guest Acct and i forgot my password. Is there anyway to get it reset or something?
log in as an administrator account then from there you can delete the guest account and create a new one.
if you do not know the administrator account then you need to go into safe mode for the computer. to get to safemode, just press F8 while the computer is booting up until you are given a menu. From the menu, simply select "Safe mode" and then login to the un-passsworded admin account. once you are inside just delete the guest account there and create a new one.
Jun 27, 2008 | Toshiba Computers & Internet
Microsoft Windows XP Professional Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
