Question about Nokia 3110 Cellular Phone
My nokia 3010 classic is not working properly.while inserting the memory cadr it gets switched off.alo i tried with another card.bt it shows the same problem.so i scanned and formate the card.bt no use.bt with out the card it works properly.why is it so?please assist me..
IF YOU HAVE HEARD OF NOKIA PC SUITE TRY TO UPLOAD YOUR PHONE DATA FIRST THEN DOWNLOAD A FRESH VERSION OF YOUR PHONE SOFTWARE.
THIS WILL UPDATE YOUR PHONE SYSTEM.
(A SHORTER VERSION FOR NOT WORKING IS THAT YOU MIGHT HAV PLACED A HIGHER VERSION OF MMC SO IT TAKES YOUR MACHINE SOME TIME TO ADAPT).
THIS HAS HAPPENED TO ME ALSO.
Posted on Sep 10, 2009
  • Nokia Master
  • 13,433 Answers
Do not insert a memory card while the phone is in use, turn off the phone before connecting, some phones do not like having the memory card removed while power is turned on.
  • 165 Answers
There is some problem with your memory card slote thats why when you are putting memory card the switching off. It is better you to take your phone to a original nokia service centre.
I lost my memory card passwod.......Nokia 2730 Classic...
first remove ur memory card,
then switch off ur mobile phone and remove ur sim card also,
then insert the memory card in switch off position,
and the switch on ur mobile phone and format the memory card as fast u as but within 8 sec.,
it will works properly try it now:...,
Sep 11, 2011 | Nokia 2730 Cell Phone
My phone Nokia 3110c is not showing memory card when i insert the memory card
your nokia 3110 classic has 9mb internal and up to 2GB external memory limit. try formatting your external when you connect your phone to either laptop or desktop after you have backed up all the necessary files. remove the connection safely and transfer one photo or music from phone memory to your device's external using your phone...just for the system to create folders for you. right after connect your phone to your computer and start copying or transferring files to your device's external on the proper folders.... email me if this worked thanks! darbyjohngill@yahoo.com
Jul 07, 2011 | Cell Phones
Bet ni mmcstore in my phone
just format your memory card using computer, insert memory cadr to card reader, and insert to computer, format using following command line format
go to "run" type "cmd", cammend line is open. then type : cd c:\ press enter key then type : format f:\
f:\ means removable disk name.....
Feb 23, 2011 | Nokia 7610
MEMORY CARD PROBLEM in NOKIA 2730 classic!!!!!! Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not...
Memory card is not working in my nokia 2730 classic device, even if i insert other mem.card which is working in other phones, the memory card option is not seen in my nokia 2730c device.Can any 1 assist me to fix this problem??!!!!.
Thank you.
Oct 20, 2010 | Nokia 2730 Cell Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
2GB memory card problem
No dear .its nt japan .i have same 8GB pen driver but made in chaina befor am using it bt nt 8 GB 256 MB like that its show in 8 GB right? bt v cnt use 8 GB .try to contact kingston website if u have searial no may be they help u ..
Sep 13, 2009 | Kingston 2GB Secure Digital Memory Card
While inserting the memmory card my nokia 3010 classic mobile is not working.it gets switched off.with out the memmory card its working properly.why is it so?
sir updating your phone software may fix this problem or just hard reset your phone hard reseting code is *#7780# put this code on your phone`s keypad.if this doesnt works try this format code *#7370# put this on your keypad it will format your phone........and your phone work good......
Sep 10, 2009 | Nokia 3110 Cellular Phone
Memory cadr corrupted.pls help me
first sir is to clean it up and check the memory card connections... pls remove and clean memory card... still no luck... follow the lines and jumper them with a thin magnetic wire...here is the pic
Jan 29, 2009 | Nokia 7610
N 73 screen
remove the memory card and try it work's properly. after u just insert the memory card i likely to be working.. better u need to format the memory card..
Sep 06, 2008 | Nokia 6230i Cellular Phone
Nokia 3110 Cellular Phone Logo
2,784 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
