Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower runs ok until i engage cutting blades then engine starts to cut out and backfire
    President:
  • 1,124 Answers
Could be a few reasons for this..
First try a new spark plug, new gas filter, clean the air filter and check the gas line for cracks or leaks..
If the issue still exists - try spraying some carb cleaner into the intake while it is running in short controlled bursts..
Or the carb might need to be rebuilt.. If it sat for a long time - the gas in the carb will shellac and cause it to not work properly.. Or it could be a bad float in the carb..
Good luck..
Posted on Sep 10, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
When I engage the the cutting blades, the engine stops. What is causing this?
Check the mower and be sure you have not lost a bearing or else it is not binding. check to be sure the mower deck brake is not hung up. Something is wrong in the mower deck if everything is ok until you start the mower deck. Hope this helps.
Sep 19, 2015 | Garden
Castlegarden twincut ride on lawn mower cutting out
some engines have a low oil level sensor yes. ck. oil level
Jun 02, 2013 | Garden
17.5 briggs motor back fired 1 time and now when i engage blades the motor boggs down
The engine is timed internally and externally. Sometimes when it backfires the external timing key where the flywheel and crankshaft join will be damaged enought to put the engine out of time. The engine may run but when put under a load such as cutting grass it will fail. This is about a 30 minute repair and about $2.00 in parts.
Jul 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Mar 26, 2011 | Honda Garden
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
270 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
