Blue prints red - Office Equipment & Supplies
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Why are my prints only printing the reds and blues in photos?
Please next time put the question in the correct category. I still will try to help you.
If your printer does not tell you any cartridge is empty, and it still does not use that colour it could be the nozzles of one cartridge are blocked. Check this by printing a test page, as told in the user manual. Sometimes called an alignment print.
Then check if all colours appear correct. Looks like yellow is not working correct.
May 08, 2014 | HP Photosmart 7520
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
Red and blue ink will not print
Arouse to clean the printing head and check the contacts printing heads. If you changed the inkwell, recommend to apply to service. The Process peelings heads requires the person of the knowledges and adjustments. Good luck
Oct 08, 2009 | Office Equipment & Supplies
Photo prints
Try cleaning mode on the printer, secondly a single color on a print or two or thre with one color noticeably absent means that that cfartridge is close on or is empty. EG Red Blue Yellow most of print is Ok but at end of print only blue seen means RED AND yellow are empty and only blue has some ink left. Replace ALL cartridges so your prints and paper arent wasted .
Jul 27, 2009 | Computers & Internet
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
Jun 19, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
Printing error (Canon ip1800)
replaced ink cartridges..error message appears now telling me to re align printer..can you tell me how to do this
Jul 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
149 people viewed this question
k24674
jasbo
jasbo
