Tray error invalid config - Office Equipment & Supplies
  • 776 Answers
Message:
TRAY ERROR INVALID CONFIG
What this message means:
The printer detects an incorrect configuration of the trays.
What you can do:
Turn off the printer. Set the trays in the proper configuration again.
See "Installing the Optional Tray Module" in the manual book.
Please find below a link to give you a brief idea on the process. Exact details can be viwewed from the manual only:
http://www.csudh.edu/CLASS/voffice/dell3100printer/Contents/section08.html#513263
Posted on Sep 10, 2009
3 Suggested Answers
STP162
  • 132 Answers
SOURCE: Tray Error, Invalid Config
You can restore the original factory default menu settings by initializing NVRAM. Try this and see what happens. from there I would need an exact message off the printer to help further.
Turn on the printer while holding down u_botton.gif and d_botton.gif .
The Customer Mode menu appears.
Press Menu.
Press d_bottonb.gif until Configure appears, and then press r_bottona.gif or arrowbutton_sa.gif .
Press d_bottonb.gif until Maintenance appears, and then press r_bottona.gif or arrowbutton_sa.gif .Press d_bottonb.gif until Init NVRAM appears, and then press r_bottona.gif or arrowbutton_sa.gif .
The Init NVRAM Are you sure? message appears on the operator panel. Press arrowbutton_sa.gif .
Turn off the printer, and then on again.
Posted on Oct 19, 2007
SOURCE: Tray Error - Invalid Config
Unplug the power cord well the printer is on. and it should reset it worked for me. Hope that helps.
Posted on May 08, 2007
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
How to fix a massage from zynga saying Invalid config xml.
cindy aku lupa sandi.gimana cara bukanya id 261114
Sep 12, 2013 | Zynga Texas HoldEm Poker
Sony v0x80070002aio error codes
check the installation media and the hdd config
Sep 07, 2013 | Microsoft 7 Computers & Internet
"Paper Size Error: The paper size selected in the
Problem may be the paper tray. You don't say what kind of printer you have and my psychic abilities are nil.
The paper tray has sensors that tell the printer what size paper is in the tray. Make sure that the tray guides are set correctly.
By the way all paper trays are "in" trays.
Print out a config sheet to see what size paper the printer is set up for for each tray.
Jan 11, 2011 | HP Office Equipment & Supplies
IP IOS Command not working with switch
you want to give IPs to your VLANs and also make physical interfaces members of a VLAN instead of giving IPs to physical interfaces
Mar 05, 2009 | Cisco Catalyst 2960 8-Port Ethernet Switch...
Error 49.420c
first try to upgrade the firmware
second try a cold reset
if this dont work change the formatter
Aug 06, 2008 | HP LaserJet P3005 Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Press Menu.
Oct 19, 2007 | Dell 3100cn Laser Printer
Apr 25, 2007 | Dell 3100cn Laser Printer
201 people viewed this question
jasbo
jasbo
