Question about Dell Latitude D620 Notebook
DELL Lattitude D620 freezes
My boss has a DELL Lattitude D620 that is plugged into the docking station. It has a problem - I have the task to find a solution.
The problem is that it will intermittantly freeze when there is traffic on the ethernet port (of the docking station). I have tried updating the driver but there doesn't seem to be any updated version available.
It freezes in different applications at different times, but mostly high traffic generating software like printing PDFs or using our accounting package (MYOB) to our server. Some other times it freezes when Adobe Acrobat and MYOB are not running so I don't think it is specifically those applications.
It does not appear to freeze when using the wireless adapter (but of course the speed is slower) - this is not preferred.
It does not appear to freeze when uning the internal ethernet adapter.
It just seems to freeze intermittantly when using the adapter in the dock.
  • 151 Answers
Re: DELL Lattitude D620 freezes
Check the dock, there might be a problem in the dock, you can also try insulating the edges of the dock with some tapes before docking and plugging the dell, sometimes a short spike of static can hang the computer. If all else fails, dell has a pretty good customer support, you can go contact them...
Posted on Dec 10, 2007
0 characters
3 Points
Dell D620 laptop screen won't come on after disconnect from docking station
please use the following small secret. Disconnect the power adapter from the laptop.
2) Dissasembly the batteries from the laptop.
3) press the power button in ON with the adapter+battery disconnected from the computer. and maintain press the power button by EXACTLY 60 seconds.This liberate the ESD.
4) Try again.
God bless you
Mar 05, 2013 | Dell Latitude D600 Notebook
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
Jan 16, 2013 | Dell Inspiron 1545 Notebook
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
Dec 31, 2010 | Dell Latitude D620 Notebook
Does lattitude d620 contain camera
Dell Latiture D620 does not contain web cam.
Dec 14, 2010 | Dell Latitude D620 Notebook
Dell lattitude x300 can't find driver wireless connection on docking station
but may as you know that the anttena for wi fi in the laptops located in the side of monitor so it is polarization issue sure when you open the laptop screen it will be different when you close it to put it inside the docking station>>>to solve this you can change the direction of your router anttena
wish that will be helpfull
Oct 31, 2009 | Dell Latitude X300 Notebook
Close to the same issue, Latitude D520 freezes at random
Have you checked the system events? I suggest you check the device manager too, is there any device working unusual? Feel free to visit digitalsupporttech for getting help.
Aug 25, 2009 | Dell Latitude D620 Notebook
Latitude D620 beeps when it connects to the internet
go into your Intel PROSet/Wireless Application Settings (issue a Control + P from within the application) window. The setting that I changed was to uncheck the 'Show Information Notifications' box. This seemed to work for me.
Jun 02, 2009 | Dell Latitude D620 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?) will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
No internet when docked.. needs network controller
Assume the docking station is powered. I have seen funny behaviour with my docking station. Sure way for it all to work is, everything off, fit to docking station, turn on with power button on docking station. Ensure network cable plugged before this.
Sep 16, 2008 | Dell Latitude D600 Notebook
Dell Latitude D620 Notebook Logo
1,480 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
