Question about Belkin Computers & Internet
Can i interface a captioned telephone with a router
How do I get my truemobile 2300 router to activate?
Posted on Sep 10, 2009
How to reset Linksys RTP300 to default by code using a telephone handset connected to the device?
You can either:
1. Press and hold the reset button for more than 30 seconds while the unit is powered up.
2. Log into the Web interface, go to the "Administration" page, and perform a "factory reset" from the factory reset subpage.
May 03, 2011 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Tip
How to set up router
Router set up is very easy. You will need to access the router set up interface to make changes on the router.
If you are not able to go online using the router then you will need to check the settings of the router.
First make sure that your computer is able to go online when connected directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.ind network key.
Router set up for Cable Internet service provider :
This connection type uses the MAC address of the main computer to identify your connection. They generally register the MAC address of the main computer. So the MAC address is everything in this connection type. Now we set up router using the MAC address of the main computer. Main computer is the computer which was able to go online through the modem. Use only the main computer to set uo the router.
Connect the modem and the computer to the router . Check the IP address on the computer.
According to the Default gateway value open the set up interface of the router. Once you open the set up interface, you will need to clone the MAC address of the computer. Then change the wireless settings on the router and your router is ready to go.
Router set up for DSL Internet service provider.
What is DSL connection?
DSL (Digital Subscriber Line) is a high-speed Internet service that competes with cable Internet to provide online access to local customers. DSL operates over standard copper telephone lines like dial-up service, but is many times faster than dial-up. In addition to being faster than dial-up, DSL does not tie up the phone line. Coexisting with telephone service in this way allows users to surf the Net and use the phone at the same time.
There are two types of DSL connection
1 ) PPPOE : In this connection type you will get user name and password from the Internet service provider. Your computer will not be able to go online when connected to the modem only. You can open the router set up and change the Internet connection type to pppoe and type the user name and password for the ISP. After that change the wireless settings of the router and it will be ready to go.
2) DHCP : In this connection type your computer will be able to go online when you connect it directly to the modem.
you don't require the user anme and password for the ISP.
In this connection your computer will get a private IP address from the router. According to this the IP address of your router will change. Change the wireless settings of the router and it will be ready to go online.
Click Here for step bi step instructions
on Dec 03, 2009 | Computers & Internet
My LAN connection from my Dlink wireless router does not work with my computer? It does work when I bypass the router.
Some ISPs (Internet Service Providers) require you to "register" the 12-character MAC-address of a network device, such as the router's WAN interface, or the computer's network interface, before you can use the ISP's network.
Telephone your ISP, and ask them for "support".
Jan 10, 2011 | D-Link Xtreme N DIR-655 Wireless Router
No internet connection
If your computer is able to go online through the modem only then your modem is working properly, we will need to check the settings of the router.find network key.
Click Here for more info
Dec 18, 2009 | Belkin Computers & Internet
I cant configure my mbr624gu router with usb 598 mobile 3g internet
Click here for step by step instructions
My belkin router won't connect to internet, I set it up as the install wizard tells me but when it tries to connect to internet, it takes 10 tries and there is an error, it was a used router we bought so...
First, turn-off the DSL-modem (or the cable-modem).
Then, turn it on.
Check that you have a "straight-through" Ethernet cable -- all 8 coloured wires at one end must be in the SAME order at the other end. Do not use a "cross-over" Ethernet cable.
Check that the Ethernet cable from the modem is connected to the 'WAN' port on the router, not to one of the 'LAN' ports.
Turn the router off.
Turn the router on.
Reconnect to the router's web-interface, and see if the 'WAN' side of the router has obtained an IP-address from your ISP (Internet Service Provider).
Some ISPs require that you "register" the MAC (Media Acquisition Control) Address of each device that you connect to their service. So, browse through the router's web-interface, and find the "MAC-address" of the router, which will be different than the MAC-address of the network-adapter inside your computer, and telephone the ISP, and get them to "authorize" the MAC-address of the router.
Telephone your ISP -- they can "troubleshoot" your cable-modem from their end.
Nov 26, 2009 | Belkin (F5D7230-4) Router (587009)
Can't configure my router to my modem, i follwed the instruction already from the manual. it still didn't work. still can't connect to the internet
Nov 16, 2009 | Cnet CWR-854 Router
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
12 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
