Question about Plumbing
GENERAC POWER WASHER PUMP
Bolts break off on pump generac power washer 22 psi
  • 5,603 Answers
Check the pressure limiting bypass valve. Also make sure the replacement bolts are "rated". They must be a certain "grade" which defines their load rating. Make sure they are torqued to spec.
Posted on Sep 11, 2009
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
My powerwasher Generac model# 0060223 is spraying water I think from the pump. Any ideas as to what is wrong.
if you did not winterize it it might have froze up and busted I was given one years back that si what happened to it before I got it and luckily I was able to fix with some lock tight spread on a thin layer and clamped it tight for several days to cure out
Apr 17, 2015 | Generac 6022/5989 2700 PSI 2.3 GPM 196cc...
Oil
Contact company, they should be able to answer this. Rule of thumb 10-30 is a good all around oil.
Apr 13, 2014 | Generac Generator 5989 2,700 PSI 2.3 GPM...
My new 2500 psi generac power washer will not start
is it getting fuel ? Do you know if it is getting a spark ?
Sep 14, 2013 | Generac Pressure Washer - 6020
How much oil do you put in the pump for a generac pressure washer model # 01676?
Check and see if there is a sight glass on the side of the pump. If there is, just fill it until the oil shows up about half way in the sight glass.
Sep 23, 2012 | Generac Generator 5989 2,700 PSI 2.3 GPM...
Pressure washer surges
This could be your unloader valve taking in account the engine isn't surging. Does the engine run smooth? Do you have at least 50 psi water pressure feeding the pump? Inlet screen clogged? ALL tips act same way or no change?
Sep 08, 2012 | Generac 2700 PSI 2.3 GPM Gas Pressure...
I own a Generac power washer model 01292=1 type 6670CP GPM2.9 PSI 2300 and request the owners manuel for this model Thank You Al Bonfardino albonfardino@yahoo.com
Go to the Briggs and Stratton website and go to their generators then to Generac. You should be able to track down a link to putting in your model number. (4) PDF manuals show for that model. http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm?rd=1
Apr 30, 2010 | Briggs Garden
Pump appears to be shot in Generac 2.3 gpm 6hp Briggs-powered pressure washer. Anyone know how to diagnose pump problems?
Mine blew up. The OEM is ****. Went on-line to buy a similar but more powerful pump. There are lots of pumps that are an easy bolt on. It's mostly standardized. Google "pressure washer pumps"
Apr 29, 2010 | General Garden
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Plumbing Logo
242 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
