Question about Whirlpool GHW9200L Front Load Washer
Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I get 3 short beeps when I press the 'Power' button. Power does not come on (it's plugged in and there's power to the recepticle). The only other button that works is the 'Controls Lock/Unlock' which turns red when held for 3 seconds.
I already tried unplugging, resetting the C/B, holding in the 'Power' button. I even opened up the machine to look at the CPU hoping to see a reset switch. Nothing has worked so far. It's likely something simple that will cost several hundred dollars to have a 'professional' fix...unless there's someone in syber-space who knows the fix and wants to share.
  • 4 more comments
  • jbrit702 Feb 05, 2008
    I have the exact same problem. I have removed the top cover of the unit, jiggled some wires, looking for any wiring problems (F70 code flashes, which is an electrical problem), and I have been able to get the unit to power up. However, the code comes back, and the unit will not power up after about 2-3 more loads. I would also appreciate any advice.
  • Anonymous Mar 04, 2008
    I am also having the same problem. We have only had washer for one week so I will have repairman look at it.
  • brandondle1 Jan 26, 2009
    i have the same problem, too. machine is plugged into working ac receptore, but machine does not power on.
  • BNemeth May 06, 2009
    I have the exact same problem with my WFW9200SQ01 Front Load Washer. My machine actually gave a single tone and listed F71 as the error code on the user display. After reading other posts, I attempted to unplug the machine for 30 minutes. When I plugged it back in, it put me in the current state. 3 beeps when pushing power and only other button that works is the lock button.
  • Anonymous May 12, 2009
    Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!
  • Anonymous May 17, 2009
    Same problem power button beeps three times when pressed.
  • 20 Answers
I have the same problem. Did you ever find the solution to this problem?
Posted on Nov 03, 2009
How do I start a Whirlpool duet HT washer?
plug it in, press power button (blue button on left) turn dial to desired cycle then press and hold the blue button on the right until u hear a click then relese. if it doesnt light up the display when u press power the washer is broken.
Mar 11, 2013 | Washing Machines
I have a duet ht washer.the control lock is on ,how do i cancel this? I have forgotten .THankyou Janet
To unlock the control lock press and hold the cancel button down for 5 sec or till you here a beep.
Good luck
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F32 comes up when we just installed our new Whirlpool Duet Washer WFW9200SQ.
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not start
This is joyce
Go to whirlpool.com and download your document to your machine and see what it has to say about your particular machine if that will help if not you may have to get some proff. help.
thanks
joyce
Feb 19, 2009 | Washing Machines
Beeps 3 times when Power button is pressed
hi im josh in cebu phils. the problem is your washer is on a short circuit. try to check the wires if it has no cut.or loosen. good luck.
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht wouldn't start
remove the lower front panel,3 screws,side up and off,there is a tech sheet inside on the panel that should help you ,let me know what you find-mike
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT WFW9200SQ/A
Plug off the wall. Close the wall faucet and check the hose & small screens on it. Open the faucet to see if the flow and pressure is good (keep bucket handy). Refit carefully, try machine. Code is nt seen anywhere as you said.
Jan 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
930 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
