Question about Hobart Dishwashers
NEED SOURCE FOR HOBART DISHWASHER PARTS
NEED SOURCE FOR HOBART PARTS
  • Hobart Master
  • 19,396 Answers
    President:
  • 1,653 Answers
Call Hobart directly in the UK on Tel: 0844 888 7777
Posted on Sep 10, 2009
Hobart dishwasher cl64e is stuck in rinse cycle
Just a guess here... Mike Lovelace,
But your "DELIME" procedures have not been followed
and/or your dirty water detector needs to be
cleaned or replaced...
Contact
HOBART
701 S Ridge Avenue, Troy, OH 45374
1-888-4HOBART • www.hobartcorp.com
Alternatively look up WHALEY Food Service
or Heritage Parts...
Hobart Parts Distributor Heritage Parts
Whaley
Parts Manual HOBART CL64e
Hope this helps
Carnac the Magnificent
Oct 10, 2017 | Hobart Dishwashers
Looking for parts for Hobart WM5H Dishwasher.
Here's the link to get Hobart parts.
http://www.hobartservice.com/parts/default.aspx
I hope they have what you need.
Bobya
Aug 19, 2011 | Hobart Dishwashers
Good morning, I have 01 Hobart dishwasher AM14, i need to be replace rinse sensor probe and temperature sensor for booster heater.But I can't to find Hobart part number Please help me.Thank you.
294692 for the rinse probe.
"temperature sensor for booster heater"? Do you mean the thermostat? If so, part number is 274161.
Parts breakdowns and part numbers are available at www.hobartservice.com. Click "Parts" on the left, then click "Hobart SmartParts System" on the next page. You'll be asked a series of questions to identify your piece of equipment, and then you'll get a parts list and have links to parts breakdowns for various sections of the machine.
Nov 20, 2010 | Hobart AM14C-155 Dishwasher
Have a hobart LX18 it will not fill can you help
hello,
A Dishwasher is a high quality product that focuses on energy efficiency. In addition to saving money on electrical use over other machines, they use less water than the average dishwasher. When your Dishwasher is not filling with water properly, before you call for a service appointment, check the components yourself.
    instruction
  1. Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
    If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
    There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
thanks.
Oct 23, 2010 | Hobart Dishwashers
Dishwasher does not spray hot water
Can you give me a little more detail?Is this part inside or outside the machine?Any wires connected to it?What do you mean by base water source?I'm a hobart tech.
Feb 25, 2009 | Hobart AM14-253 Free-standing Dishwasher
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Need motor & impellor for Hobart AM8
I havn't seen an AM8 in over 15 years.
Hobart will keep parts available for quite a few years past end of production, but this may be too long. The AM 10 and early 12's are compatable.
You need a 6 bolt pump to motor. Yours has the old cast iron wash arms. All the new have light stainless arms. Just checked my records. the new AM12 which superceeded your design was in 1981. Perhaps look around for a used AM14 which fits your tables and plumbing. Confirm the voltage is compatable.
The AM15 is the current spec and is far superior.
Jan 09, 2009 | Hobart AM14-253 Free-standing Dishwasher
Door tension spring broken.
The columbus hobart branch should have this part.Need any more info let me know.
Dec 08, 2008 | Hobart 41 in. AM14-255 Free-standing...
Dishwashers Logo
1,093 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
