Question about Samsung SyncMaster 740b 17" LCD Monitor
Vertical green colour line appears on left part
    Scholar:
  • 53 Answers
This is bad - that means there are loosed contacts between scaler board and flexi-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flexicables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, uscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flixicable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Posted on Sep 10, 2009
  • 294 Answers
Hello.
I would have to see the vertical lines in order to ascertain the cause. Generally, however, they are from problems in the video processing circuitry surrounding the jungle chip. Also mention the indications of rfi correctly. So if you have another easily transportable tv in another room that you can bring in and set it side by side with the jvc, check it also for the same problem. RFI can be very deceiving.
Then let me know further. But don't service it if there is any chance of it being something external to the tv!
please feel free to give the problem in detail manner so that we can get a more clear picture of your question. as i can not see your TV pertionally so detail is all that will help both of Us
Regards Gizokieth
3 Suggested Answers
SOURCE: SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
this discoloration problem occurs commonly in every1 s pc ... this problem occurs due to the nearby magnetic field emitting appliances just like speakers... so what u have to do is u must keep some gap with the speakers from the monitors & after that press menu button on ur monitor and give degauss.... this will solve your problem....
Posted on Feb 06, 2008
SOURCE: sky blue colour vertical line appear on the screen .
What is the problem with your monitor? Please give details on the problem of your monitor, this will guide me to suggest a solution to the problem.
Take care.
Posted on Jul 17, 2010
Vertical colored lines
Hi.If you have a Nvidia Graficcard, it could be it.overheating problem at the motherboard.you need 2 replace motherboard, or reflow, reball graficchip.it's a common problem at Nvidia 6XXX, 7XXX, 8XXX model grafics..
Dec 29, 2013 | Sony VAIO Computers & Internet
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
Sep 19, 2013 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Vertical green line on left side of my laptop lcd
lenovo G450 a vertical line appears on the right side of screen. it is of pink colour.
Jul 03, 2010 | Samsung 204T 20.1" TFT-LCD Monitor
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
Vertical lines on screen
3 problems:
1. your monitor but i doubt it
2. vga component in your computer
3. atx component in your computer.
try go to a friend and make some changes. don't buy anything first. just test them to see what's bad.
Nov 01, 2009 | BenQ FP71G+ 17" LCD Monitor
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Lines on tv screen
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
Nov 26, 2007 | Televison & Video
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Oct 12, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung SyncMaster 740b 17" LCD Monitor Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
