Question about Car Audio & Video
Jaguar s type 1999 sound system ..sound ok but no display ,is there any LEDs that can be changed or is it down to dry joints
  • 410 Answers
First make sure your red power wire and pink power wires all have 12v. (I'm not actually sure about the Jag's wire color pattern) Check radio fuses.
No LED's are in the Display screen part. Remove the radio, Take the front cover area apart, The liquid crystal display is powered through a small rubber like conductor. It was probably moved out of place by something pulling on the radio front. You'll need to clean that rubber connector with alcohol and all LCD mating surfaces then reassemble.
Posted on Sep 10, 2009
Does drive shaft on jaguar 1999 xj8 need greese
the rear drive shaft universal joints should have grease ******* but someone in the past may have changed one or more with sealed joints you need to look to decide jack up the car remove out of P release handbrake rotate rear wheels and check the universal joints for grease *******
Apr 01, 2017 | 1999 Jaguar XJ
Where is the amplifier for the audio system located on an s type jaguar 2002
has your car got premium sound system? if so the power amp is in the boot behind the inner wing trim panels on the lh side i think. and if it goes down it burns out ALL of the speakers, test the speakers with a ohm meter i suspect they are all open circuit
Jan 19, 2015 | 2002 Jaguar S-Type
How do you change the clock in a 2004 jaguar x-type
If not touch screen
Press and hold MODE until TA Volume is displayed
Release and press MODE until CLOCK SET is displayed.
Select format 12 or 24 hour using up/down keys
Press and release MODE
if 12 hour use # to select AM or PM
Use keypad to enter time in 4 digit format i.e 0315
Press and hold MODE to exit
May 15, 2010 | 2004 Jaguar X-Type
Hi, I have an 1995 Jaguar XJ6 3.2 litre. The antilock warning has been illuminating occasionally in the past,more frequently now. Brake fluid levels appear OK. What fix would be required. Thanks in...
I would have to plug a diagnostic computer into the car and interrogate the ABS controller for diagnostic trouble codes to find out what part of the system is causing the problem being detected and triggering your light to illuminate.
Feb 26, 2010 | 1995 Jaguar XJ6
How to unlock jaguar s type 1999 radio, when
Leave the ignition on for 20 mins as that some times clears it and allows you to try again 3 more times
Feb 14, 2010 | 2000 Jaguar S-Type
S type jaguar gearbox
Hello astra....Un fortunately the oldes S-Types do suffer from this.....If you dont want to chance a new gearbox,ya gotta live with it ..As long as you have your foot on the brake its ok so sit at the lights while in D
Dec 06, 2008 | 2000 Jaguar S-Type
1999 Jaguar XK8 radio problem
You should reboot the system, sometimes these cars hicup so to speak.
Disconnect the battery, both sides, then with it still disconnected turn the key to crank 3-4 times (with the battery disconnected, this just discharges all the ecu's and clears any held memorys)
Reconnect the battery (pos + first)
After that you need to relearn the windows, with the key on or the car running send the windows all the way up, then one at a time, hold the button to bring 1 down and continue to hold for 5 seconds once it is all the way down, do the same for the up position, repeat on the other side and you should be good to go.
JPTCAT
Aug 23, 2008 | 1997 Jaguar XK8
Works for a few minutes then shuts down
You both have a collection of dry solder joints and or bad capacitors. Check for any sign of buldging capacitors on the power supply board and replace as needed with the exact same values.
The dry joints in the solder are normally around the larger items on the board like transformers etc and places that alot of heat builds up. Check the regulators and other area's near there, and also check areas that sit above them when the monitor is in normal operating mode..hot air rises..too bad electrical engineers work on flat screens =)
Good luck to you both.
Apr 27, 2007 | Dell 1503FP 15" LCD Monitor
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
