Question about HP Office Equipment & Supplies
How do i know which print heads need replacing?
  • HP Master
  • 19,396 Answers
Inkjets have either different heads for each color, or one printhead for black and one for color. Some model may have just one printhead (eg. printers using Lexmark one cartridge).
Replace the printhead which color is not printing or smearing.
If you are not sure replace all printheads. That would be a good idea, since one printhead is gone, remaining printheads having same service history may fail soon.
Regards.
G.
Posted on Sep 10, 2009
    President:
  • 1,653 Answers
The HP diagnostic error codes will tell you what needs replacing. Run a self test and print test to see the results. This should identify any harware problems.
Canon Pixma Pro9000 - my printer was working fine and now when I send files to print, it goes through the motions like its printing but nothing actually prints on the page. I thought maybe it was a driver...
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 01, 2013 | Office Equipment & Supplies
I have a lexmark z715 printer connected to windows xp. recently it stopped printing. the paper moves and the machine makes sounds similar to printing, but it doesn't print. i think the sound is s
Feb 23, 2013 | Lexmark Z715 InkJet Printer
CANON PIXMA MP520 NOT PRINTING BLUE
Nov 27, 2012 | Canon PIXMA MP520 InkJet Printer
I have a Brother MFC-295cn. I first ran out of blue ink. I replaced it and it was working fine. Then it started printing out blank paper. it goes through the motions but paper comes out blank. Anyone...
Nov 17, 2012 | Brother MFC 420CN All-In-One InkJet...
My printer is not made by brother. it is Hp model 6500 I do not know how to clean the cartridge. The cartridge is new not a refill
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 14, 2012 | Brother MFC-5440CN All-In-One InkJet...
The repair shop I took my HP Photsmart 3200 All-in-One to told me the print heads had been destroyed by using refilled ink cartridges from Office Max and that the print heads were NOT replaceable, that I...
The print heads are not replaceable unless you know what you're doing. Even if you did know what you're doing, you need another bad printer of that series to exchange the print heads. It is easier to just buy a new printer that uses the same 02 ink you're used to, especially if you have a CISS system.
Oct 05, 2010 | HP Photosmart 3210 Printer
My printer will barely print. I have cleaned my head & did the other maintenance steps, but it is no better. Can you help
You need to replace the print head if you done ll that and no go.. The printer will need to be serviced if you do not know how to replace the print head. - thanks
Sep 23, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Print head error message
hi
if yr printer is under woranty u need to do company services system coz i think that u do what as u abov say that u do a initial stape or if yr printer not on woranty and if u know a normal clining system do cline pritner otherwise u need to replace head...
if yr printer show red light blink do press 5sec. then print it..may be it's help u if u have any quary tell me feel free...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Zebra 110Xi III Plus Thermal Printer print quality degredation
You can try cleaning the print head with some isopropyl alcohol and a swab but be sure not to touch the element with your fingers that can get grease from your finger on it causing the oil to burn out the element very quickly. You can also check the Print head element its self. What you are going to be looking for are white spots or streaks on the print head. If you see white spots or streaks your print head has reached end of life and needs to be replaced. If instructions are needed on how to remove the Print head and or identify what DPI Print head you have installed please let me know I can post something up for you. If a Print head is needed please let me know as well. I currently carry them in stock new.
Thanks
Rory Cardenas
708-597-4222 x240
Dec 13, 2008 | Zebra 110Xi III Plus Thermal Printer
Does anyone know how to remove print head?
The print head nozzles is clogged but good. None of the cleaning the machine can do will clear it. Been there and trid that. Doesn't work. The clogs need to be dissolved with a specialty clog buster and probably will need to soak at least 24 hours, maybe more. Don't deep clean any more as you will put so much in in the absorbent blotters on the inside of the printer that you will trigger an error code and not be able to print until the absorbant pads are replaced by a service tech for about $100.
Aug 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
117 people viewed this question
Seeker5211
Seeker5211
